Where to Buy Best Battery?
   / Where to Buy Best Battery? #21
Wirehead
:welcome: to TBN
Model number?
Or part number?
After many years, my X485 battery failed... bought the X485 spring 2003.
   / Where to Buy Best Battery? #22
Thanks for the welcome Beenthere. Who makes the x485.
   / Where to Buy Best Battery? #23
For my JD 790, I would like to get a good solid non-oem battery. I have read that Optima makes a fine yellow top. Any recommendations? Best prices?
Thanks.
Optima is an AGM. I use a red top in my WRX because it is 12 lbs lighter.
I consider the Odyssey AGM to be the absolute best available. It is also sold as the Sears Platinum.
ODYSSEY battery - Official Manufacturer's Site
   / Where to Buy Best Battery? #25
John Deere as listed under profile.
In your first post you asked..
but does anyone have a model number for the 790 battery?
What do you mean by a "model number" ?
   / Where to Buy Best Battery? #26
I agree with the above.^^^^
I have had the Odyssey batteries for several years and are my favorite. They hold a charge without the need of a trickle charger all year. For the vehicles with every day use I have the Walmart Everstart Max, since these stores are everywhere service is close and most are less than $80 for a 6 year battery. With about 25 batteries to maintain I can't afford to have all Odyssey batteries and not all sizes are available. Sears Diehard Platinum are Odyssey batteries but are only available in about 2 or 3 sizes.
   / Where to Buy Best Battery? #27
Can't speak for all Walmarts- but ours sold Exide sourced batteries and personally had many of the ones I purchased fail within 3 years, a while back noticed that Johnson Controls was producing batteries for Walmart, same supplier for Les Schwab tire stores (north west US) and they have been very reliable, So have purchased a couple lately from Walmart and so far so good..
   / Where to Buy Best Battery? #28
Battery brands sometines change suppliers and sometines have multiple suppliers.
The most basic quality gage is the length of 100% replacement.
   / Where to Buy Best Battery? #29
I agree with the 100% replacement, and find if they last this long without failure they will usually make if for the full life of the specs. I find that all most all brands of the starting batteries seem to be good enough these days. I do prefer to have a better quality battery for deep cycle and marine uses though.
   / Where to Buy Best Battery? #30
Maybe not the best brand, but I got a Advance Auto Marine Starting battery for my 861 Diesel this past Spring. I read the Marine batteries were a little more robust than standard car batteries (they stand up to wave bouncing boat hulls) and this one had 800 CCA and was cheaper than a similar car battery with the same CCAs. It also has 2 extra connection terminals with a nut I can used if needed for accessories. So far, it has worked great, but I haven't had to use it in cold weather yet; time will tell.
ONE NATION UNDER GOD CONCRETE STATUE (A58374)
ONE NATION UNDER...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
12FT X 20FT LIVESTOCK METAL SHED (A58216)
12FT X 20FT...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
