Where to buy a new Kubpta tire?
   / Where to buy a new Kubpta tire? #11
I believe this is the same tire that's on the L4701. If so, you can buy a tire and rim though wholegoods for about what anyone else will charge for just the rubber tire.
   / Where to buy a new Kubpta tire? #12
I believe a new tire and wheel can be purchased from Kubota for less than $300 when going through whole goods (not parts). This might be an option depending on how much the tire cost plus mounting.
I purchased a BX tire and rim through whole goods, and yes it was cheaper than buying just the tire.
   / Where to buy a new Kubpta tire? #13
I'm unfamiliar with the classification "wholegoods" . Would someone enlighten me and advise where to find?
Thanks!
   / Where to buy a new Kubpta tire? #14
When I was looking for my front tires for my M4700 the Tupelo, MS dealer quoted far more than the $300 I eventually paid at Dickinson Kubota, Fredericksburg, Va for 9.5x22's. And I specifically asked for whole goods price.
   / Where to buy a new Kubpta tire? #15
Whole goods are sold by the department that sells the tractors. Parts prices are typically through the parts department. Stop by you local Kubota dealer and talk with the tractor sales person. They should know what "wholegoods" prices are since this is the resource they use to price tractor sales from.
If you strike out call Messick's for the straight answer.
For reference you might consider googling Kubota wholegoods and you'll find a few PDF examples so you can see first hand.
   / Where to buy a new Kubpta tire? #16
My friend needed a pair of fronts for his B21 and priced at major truck and tractor outlets.
Kubota's price for tire and rim (mounted) from dealer was less than bare tires at tire wholesalers.
   / Where to buy a new Kubpta tire? #17
Below is an example from the Wholegoods price list for a 8.3-16 tire/wheel assembly albeit for a B series tractor. As you can see, the price list is from March 2014, so it should be fairly accurate. (see wholegoods picture below)
Wholegoods: Kubota 8-16 Wheel.png
If a tire and wheel assembly was sourced from Kubota through their parts department the tire assembly would be $398 versus $248 through wholegoods. (see parts below)
Parts (from Messick's website): Kubota 8-16 wheel via parts.png
Added in edit 03-03-15:
This is for a L-Series tractor.
WARNING: User responsible for verifying Part Numbers for L4400. Above info for reference info only.
   / Where to buy a new Kubpta tire? #18
Make sure that the side wall ply rating is the same as your old tire. I also have a front loader and when my tires wore out I decided to get the cheaper tires from a tire company. Wore out the new front tires in 40 hours because of the front loader use. Fortunately the place that mounted my tires had my old set in a dumpster, ended up putting the old tires back on until I could find tires with the same side wall ply rating.
   / Where to buy a new Kubpta tire? #19
definitely Kubota whole goods that way you get a tire already mounted on a wheel not just a tire always good to have a spare must go thru sales not parts.
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54756)
PREDATOR TRI-FUEL...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A56129)
2020 VOLVO...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
