where to buy a decent diesel fuel can
   / where to buy a decent diesel fuel can #11
Just use a golf tee to plug a 1/8" vent hole drilled in the can.
   / where to buy a decent diesel fuel can #12
Flatheadyoungin said:
the sheet metal screw might be a good idea.......is there anything else you fellas can think of that could be opened and closed?
Yes, your wallet when you go to buy fuel. I want a gas can that doesn't cost so much to fill. Any ideas?;) :D
   / where to buy a decent diesel fuel can #13
I use a couple WWII metal cans (jerry cans)... a bit rusty on the outside but work great!
mark
   / where to buy a decent diesel fuel can #14
The the storm just comming though I broke down and bought another 6 gallon plastic jug at Sams. $14. I have plenty of gas cans at the other house but.......
I think I'm going to splash this 6 gallon jug to diesel by splashing on some yellow paint. I think I'm also going to break down and vent it myself.
I like the golf tee idea!! Or someone needs to find a source for those little yellow plastic ones and we can put them on the jugs.
As far as keeping then in the back of the truck, it ain't pretty but it also ain't always seen, but I have some of those stake post tie downs in my truck bed. On each side I have some 14-2 romex tied to them. The romex is long enough(couple feet) tie around stuff, boards, generators, bikes, chairs, whatever. They are like big twist ties. Line the gas cans in the back, loop the romex through the handle, give it a twist and the stay put. Wnen not in use I tuck them in the bed where you can't seen them from the outside. Cheap but effective. Ahh I found a pix, you can see the white romex tied to the back stake. VERY useful.
Rob
   / where to buy a decent diesel fuel can #15
it used to be a 5-6 gallon plastic gas can cost about 8 bucks......to fill it up was about the same.......
not now.....:mad:
when i told my buddy that TSC has diesel fuel cans on sale for $6.99 and that i bought two, he laughed and said, "yeah, but can you afford to fill them up?"
   / where to buy a decent diesel fuel can #16
Wedco makes a nice diesel fuel can. If you google them the parent company is The Plastics Group. They also make cans for Briggs and Stratton. I think you can buy the cans from a dealer. Go to Briggs and Strattons web site and search for fuel cans. This will give you a model # and picture of the can.
Solo
   / where to buy a decent diesel fuel can #18
slewisma said:
This is the style I have and with the gas cap on the fender and the grab handle next to it on the BX24, I find this is the only easy way to fuel up without making a mess out of the tractor. The trick is to make sure your finger / glove isn't blocking the vent part of the button you press to let the fuel flow.
1*I still may upgrade to something bigger with a pump when I get the shed done but this thing works okay for now.
*I did that here.http://www.tractorbynet.com/forums/1416095-post3.html
1*Do it; you'll like it much better.
   / where to buy a decent diesel fuel can #19
   / where to buy a decent diesel fuel can #20
gunther-gifts_2009_3299975
Holds about 8 oz.
Caterpillar D3C LGP Crawler Tractor Dozer (A55851)
Caterpillar D3C...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
