where to add the hyd. fluid
   / where to add the hyd. fluid #1
chuck1764
SE Indiana
Yanmar 1700 1975 ford 3550 TLB
1975 ford 3550 where to add the hyd. fluid
I just bought a 1975 Ford 3550 ind. where do you add and check the hyd.fluid for the hoe and fel ?
Chuck
   / where to add the hyd. fluid #2
Re: 1975 ford 3550 where to add the hyd. fluid
If you can post a couple of pictures it would help my memory on that model, both sides would help. That one originally had a two piece loader frame, RH & LH, with a crossover pipe connecting the two. They served as the hydraulic reservoir for both the loader and the backhoe. The filler was located on the left loader post. Later, if I remember correctly, the filler was moved under the radiator shell with access at the top. Hope this helps some.
   / where to add the hyd. fluid #3
Not sure if yours is the same arrangement as my 6000 but the location of the hydraulic filler had me puzzled for a while. It was finally identified as a common filler for the power steering located under the left side of the engine cover just behind the radiator and in front of the air intake oil bath - see picture - the filler is in the top left corner.
Cheers
Alan
2016 Nissan Frontier Extended Cab Pickup (A50323)
2016 Nissan...
1240 (A50490)
1240 (A50490)
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
