where to add the hyd. fluid
   / where to add the hyd. fluid #1
chuck1764
SE Indiana
Yanmar 1700 1975 ford 3550 TLB
1975 ford 3550 where to add the hyd. fluid
I just bought a 1975 Ford 3550 ind. where do you add and check the hyd.fluid for the hoe and fel ?
Chuck
   / where to add the hyd. fluid #2
Re: 1975 ford 3550 where to add the hyd. fluid
If you can post a couple of pictures it would help my memory on that model, both sides would help. That one originally had a two piece loader frame, RH & LH, with a crossover pipe connecting the two. They served as the hydraulic reservoir for both the loader and the backhoe. The filler was located on the left loader post. Later, if I remember correctly, the filler was moved under the radiator shell with access at the top. Hope this helps some.
   / where to add the hyd. fluid #3
Not sure if yours is the same arrangement as my 6000 but the location of the hydraulic filler had me puzzled for a while. It was finally identified as a common filler for the power steering located under the left side of the engine cover just behind the radiator and in front of the air intake oil bath - see picture - the filler is in the top left corner.
Cheers
Alan
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
Round Bale Feeder with Skirt (A50515)
Round Bale Feeder...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
Detach Trailer (A50514)
Detach Trailer...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
