Where to add hydraulic fluid on Ford 3600??
   / Where to add hydraulic fluid on Ford 3600??
I am going to pick up some fluid today. I do not believe it is fully dry, but with my luck....I just hope not.
Thanks for the tips and information, this is a great forum. :thumbsup:
   / Where to add hydraulic fluid on Ford 3600?? #12
after filling, start tractor and lift control arm. Bleed the air out of system by the hex head screw on the hydraulic pump. Loosen screw a little, then tighten and move control arm up and down a few times. Bleed again like that until lift arms move nice and smoothe. Dont forget the transmission fluid.
   / Where to add hydraulic fluid on Ford 3600?? #13
good luck with her.
   / Where to add hydraulic fluid on Ford 3600?? #14
ANYONE KNOW WHERE THE HYDRAULIC FILL POINT IS ON LS 3010S 4WD WITH FRONT END LOADER? LOST MY MANUAL.
   / Where to add hydraulic fluid on Ford 3600?? #15
you might want to start your very own post on this subject.
yuinit is a LS? or a FNH 3010S ? not clear in your post
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
