Where to add hydraulic fluid on Ford 3600??
   / Where to add hydraulic fluid on Ford 3600??
I am going to pick up some fluid today. I do not believe it is fully dry, but with my luck....I just hope not.
Thanks for the tips and information, this is a great forum. :thumbsup:
   / Where to add hydraulic fluid on Ford 3600?? #12
after filling, start tractor and lift control arm. Bleed the air out of system by the hex head screw on the hydraulic pump. Loosen screw a little, then tighten and move control arm up and down a few times. Bleed again like that until lift arms move nice and smoothe. Dont forget the transmission fluid.
   / Where to add hydraulic fluid on Ford 3600?? #13
good luck with her.
   / Where to add hydraulic fluid on Ford 3600?? #14
ANYONE KNOW WHERE THE HYDRAULIC FILL POINT IS ON LS 3010S 4WD WITH FRONT END LOADER? LOST MY MANUAL.
   / Where to add hydraulic fluid on Ford 3600?? #15
you might want to start your very own post on this subject.
yuinit is a LS? or a FNH 3010S ? not clear in your post
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2008 GMC C5 (A55788)
19015 (A53422)
19015 (A53422)
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
