Where to add hydaulic gauge
   / Where to add hydaulic gauge #1
acadian32
Ottawa
Jinma 254
As some of you may have been reading my latest post regarding my hydraulic problem, to protect my new pump coming via mail someone suggested to add a hydraulic gauge to view from time to time and was thinking could I simply add the gauge on the spool in or our by adding a T coupling see picture I would add it with a long hugh pressure house so I could place it where i could see it Spool Valve.jpg
   / Where to add hydaulic gauge #2
That is a good place to install the tee, hose and gauge.
hello all could i use the blank one see picture thank you
   / Where to add hydaulic gauge #4
It should indicate what that port is for.
It is probably another tank port .
What is the model number and brand name on that valve?
Hello JJ thanks for the reply, the valve is NUI-ENG ZD,-F15L its off my Jinma 254 im searching on line on my end also to try and find the specification to this spool valve thanks
   / Where to add hydaulic gauge #7
What does the OUT port feed?
Does it go to the tank, or to another valve?.
Hello JJ, its the only spool valve i have on the tractor controls my loader
   / Where to add hydaulic gauge #9
Where does your 3pt get it's fluid from?
Is your FEL valve the first valve in the hyd flow path does the 3pt get the fluid first?
Hello JJ thanks for keeping the help coming... I have a separate lever to control the 3pt how this all works Tractor world is new this is my first one it is all controlled by one hydraulic pump the spool valve on the picture does only the loader in the front up-down tilt up and down, the in of the spool valve come from the pump its self and the out connect to some kind of header that close to the transmission that seems to then be distributed to other hydraulic functions throughout the tractor like the cell phone and tv :) kidding about the cell phone and tv :)
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
John Deere HPX815E (A50123)
John Deere HPX815E...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
JOHN DEERE 54D LOT NUMBER 88 (A53084)
JOHN DEERE 54D LOT...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
