where is TC34DA main PTO safety switch?
   / where is TC34DA main PTO safety switch?
Thanks for the info about the spring, Bob. All the levers on that side of the machine are at least a little tough to move. Sometimes more than a little tough (like the range select, and PTO engage). What year is your TC34DA?
I wish I had a quick attach front end. I think it would be very handy. But nope, the fellow I purchased her from didn't want to pay the extra charge, so I am without.
~Allen
   / where is TC34DA main PTO safety switch? #12
Make sure all linkages on PTO and range selectors are lubed regularly also; it will help.
   / where is TC34DA main PTO safety switch? #13
Thanks for the info gents! Had the same problem with the PTO light staying on. Followed the illustrations above and found a wire popped out of socket for the switch. Plugged back in and good to go!!!
Cheers,
Mike
   / where is TC34DA main PTO safety switch? #14
I have the same NH model with 900 hrs and yes... last Fall when clearing some brush in the woods I had the exact same issue. Reconnected connectors and it ran fine.
Last week I had something new happen, while mowing with a finish mower for a few hours, the mower just stops. I noticed the PTO shift handle had moved from the detent to about half way up. So I fully engage the clutch, throttle down, re-engage rear PTO, push throttle back up to 540 rpm and it runs fine for about 20 minutes and happens again. The second time, I left my hand on the PTO shift lever and it痴 definitely a hard mechanical pop when the lever moves forward. Looking at the service manuals... I do not see anything in the system that might cause this. The only thing I can come up with is the Rear PTO safety switch. I know what happens when the connectors are disconnected, but not sure if it could cause this if it痴 defective? Appreciate any assistance...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
John Deere 5075E (A53317)
John Deere 5075E...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Ammco Brake Machine (A55758)
Ammco Brake...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
