where is TC34DA main PTO safety switch?
   / where is TC34DA main PTO safety switch?
Thanks for the info about the spring, Bob. All the levers on that side of the machine are at least a little tough to move. Sometimes more than a little tough (like the range select, and PTO engage). What year is your TC34DA?
I wish I had a quick attach front end. I think it would be very handy. But nope, the fellow I purchased her from didn't want to pay the extra charge, so I am without.
~Allen
   / where is TC34DA main PTO safety switch? #12
Make sure all linkages on PTO and range selectors are lubed regularly also; it will help.
   / where is TC34DA main PTO safety switch? #13
Thanks for the info gents! Had the same problem with the PTO light staying on. Followed the illustrations above and found a wire popped out of socket for the switch. Plugged back in and good to go!!!
Cheers,
Mike
   / where is TC34DA main PTO safety switch? #14
I have the same NH model with 900 hrs and yes... last Fall when clearing some brush in the woods I had the exact same issue. Reconnected connectors and it ran fine.
Last week I had something new happen, while mowing with a finish mower for a few hours, the mower just stops. I noticed the PTO shift handle had moved from the detent to about half way up. So I fully engage the clutch, throttle down, re-engage rear PTO, push throttle back up to 540 rpm and it runs fine for about 20 minutes and happens again. The second time, I left my hand on the PTO shift lever and it痴 definitely a hard mechanical pop when the lever moves forward. Looking at the service manuals... I do not see anything in the system that might cause this. The only thing I can come up with is the Rear PTO safety switch. I know what happens when the connectors are disconnected, but not sure if it could cause this if it痴 defective? Appreciate any assistance...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
2023 Kubota SVL97-2 Compact Track Loader (A56435)
2023 Kubota...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A56435)
2018 Cadillac...
2021 Ford F-450 (A55973)
2021 Ford F-450...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
2006 Grove TMX25 (A55973)
2006 Grove TMX25...
