Where is a good jacking point?
/ Where is a good jacking point? #11
I jack directly under the draw bar bracket.
Ta, Roy. I haven't had to jack my 4105 yet, but I was curious as to where & how I'd go about it. I've got the floor jack and stands, but as a 'just in case' sort of thing.
And ta, George2615, for the method/procedure.
/ Where is a good jacking point? #12
Draw bar bracket works for the rear, but if you need to jack the front, the weight bracket works well. If you have a FEL, use it to raise the machine and the weight bracket for the jack stands. Just don't get under the FEL when you position the stands.
/ Where is a good jacking point? #13
Got'cha, Roy. Yes, I've got a FEL and that was the plan to do (as you've suggested for raising) anything I needed to do with the front tyres... or front in general. Good to know about using the weight bracket for the stands, though. :)
/ Where is a good jacking point? #14
Having the bucket flat on the ground should help a little with stability too when lifting the rear as it may reduce the tendency for the tractor to tip or pivot on the front axle.
Cleat
/ Where is a good jacking point? #15
I Jack the Kioti up with the jack pushing up a 4x4 under the drawbar bracket right in the middle with the floor jack extending out the rear of the tractor. I am safe even if something should go wrong. I did it a couple of weeks ago to put on the chains.
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61307)
2023 Takeuchi TL6R...
Giyi Gy-72Pro QA Mulcher (A60463)
Giyi Gy-72Pro QA...
2023 Deere 325G (A60462)
2023 Deere 325G...
30 Gallon 180psi Portable Air Compressor (A59317)
30 Gallon 180psi...
SANY SY50U EXCAVATOR (A59823)
SANY SY50U...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
