Where is 2638 made?
/ Where is 2638 made? #1
TomIre
College Grove, TN
Branson 3725
Anyone know where / who makes the 2638? I.E. TYM, Mitsubishi, etc.
Thanks. Did a bunch of Googling and couldn't find it.
/ Where is 2638 made? #4
All the 2500 & 2600 series machines are made by TYM. You will get more for your money if you just buy a TYM. But then there are other issues that have to be considered.
I personally would go with the Kioti and I own 2 Mahindras.
Just the man I need to talk with! I'm between a CK 3510 and a Mahindra 2638. Pretty much settled on the Mahindra but would love to get your thoughts.
/ Where is 2638 made? #6
Look at the 3pt hitch. Various problems with how it is designed. Get the dealer to install a quick hitch, then operate full range of motion with the top link in each pin location. Adjust the top & side links to there max adjustments collapsed and extended. You will then see what I mean.
Does it work, sure, but with limitations. If those limitations won't affect you, GREAT. :thumbsup:
Thanks. I'll take look. I will say that the Kioti's 3 pt hitch adjustment mechanism is brilliant.
Glad that's the "only" thing that concerns you.
/ Where is 2638 made? #8
It's not the only thing, but it's the show stopper for me with that model. :thumbdown:
NONE of them are perfect. There are compromises with all of them.
Just the way it is. ;)
/ Where is 2638 made? #9
I was between Mahindra and Kioti as well. The most important factor was that I have three Mahindra dealers (with full service centers) all within an hour of me but the Kioti dealers were both over an hour away. I also like that the Mahindra doesn't have DPF so no regen cycles.
/ Where is 2638 made? #10
TYM in Korea makes the budget end 2500 and 2600 models. The upscale 1500 & 1600 stuff is made by Mitsubishi in Japan. Both use the same Mahindra engines. I don't know who makes the accessories for the 25 and 2600 stuff but KMW (Kansas Machine Works) makes the loaders and backhoes for the upscale 15 & 1600 models right here in the good ole USA. Tires, accessories etc. are put on by the Mahinda distribution centers throughout the US. West Coast distribution is located in Olivehurst, CA and is part of the Beeler Tractor organization.
/ Where is 2638 made? #11
Korean tractors get Korean loaders
/ Where is 2638 made? #14
Most of the TYM built Mahindra’s have different loaders than the TYM branded machines, Mahindra uses different loader on them then stock. The 2655 lifts 3,100 lbs and the TYM one is around 2500 lbs. I am pretty sure the EMAX Mahindra’s use the TYM loader.
/ Where is 2638 made? #15
I believe all are getting Ansung these days. Could be wrong.
No. We build most of the loaders for Mitsubishi made tractors and a large chunk of the Mahindra built ones. I think it's close to an even split between Korean manufacturers (there is more than one) and us.
/ Where is 2638 made? #16
My 4110 has an ML 112 loader built by KMW, and the same engine as a Kioti, the Daedong 4A200DY. I did switch out the three point arms for a longer standard Cat 1 pair, it increased range of motion for the three point lift.
/ Where is 2638 made? #17
I am also considering both these tractors. Or the DK4210SE. The dealer compared the Mahindra 2638 to the DK4210SE. I am also purchasing the backhoe with it. The Mahindra has a Mitsubishi engine and no DPF. Also the engine displacement of the Mahindra is significantly larger 167 cu in verses 111 cu in. I am not a tractor guy. Curious to thoughts on this thread. I am not brand loyal and plan on keeping this tractor for a very long time.
FWIW, I ended up with a Branson 3725. Very happy with it after 18 months or so.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65579)
New/Unused AGT...
2019 INTERNATIONAL LT625 (A59914)
2019 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A64277)
AUCTION STARTS...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
