Where do you park/store your tractor?
   / Where do you park/store your tractor?
I keep my tractors in the barn, but I have a few implements stored outside in an open carport. I use rubber stall mats on the dirt floor, arranged so no water pools on the surface. Keeps the moisture away from the metal and does a good job controlling corrosion.
Interesting. Where did you get your rubber mats? I am considering laying a couple of sheets of plywood to cover the ground.
   / Where do you park/store your tractor? #22
I currently keep in a barn, dirt floor, which just offers protection from above, wind rips through board and batten sides. Built a lean to on side of garage, dirt floor, plan was to keep in there for easier access when it snows. Still trying to figure out a door system, open to ideas.
There is a slight 2-3" rise once I leave the lean to. Space was tight.
   / Where do you park/store your tractor? #23
I tried treated plywood but it wasn't rated for ground contact and rotted away in a couple of years.
I've had good luck with these mats from Tractor Supply:
They're actually cheaper than treated plywood and will last far longer.
I lay them on the dirt floor, smooth side up, and pitch them so no water pools on them.
   / Where do you park/store your tractor? #24
all my equipment sits in a gravelled floor pole barn. Sliding doors in front and open windows in back. No rust even on the older equipment or the newer powder coated stuff.
How close are you to the Bay Fundy / Ocean??
I always wondered how much more rust stuff near the oceans get??
Good point. I am so close to the Bay of Fundy, a ball player with a good arm could probably hit it.
No doubt the salt air plays a role in rusting.
Not too much chatter here on rust repairs or prevention. But it sounds like rust is not an issue for most of you. My main concern was rust on the hard lines that go from the FEL valve to the quick connects. About 70% of the paint was gone, replaced by rust.
I started by wire brushing loose paint and loose rust off the lines and then treated it with two coats of Loctite SF 754. It goes on milky-white and then turns black. They say it causes a chemical reaction that converts rust into a hard, impervious layer. You can leave it as-is but the directions said for "extreme" environmental exposure, you should top coat it. So I applied two coats of Tremclad rust proofing paint. Hopefully this will last a good many years.
I'm considering smearing grease or spraying Fluid Film on other parts to prevent corrosion.
   / Where do you park/store your tractor? #26
Open sided shed attached to the barn with a dirt floor. No rust after many years though the paint is more Mary Kay pink than Kubota orange šŸ˜Ž
   / Where do you park/store your tractor? #29
99% of the time it's under the lean-to I had built with the barn build.
If we get notice of the annual cold-snap, I might put it in the barn. That's really more about keeping the diesel warm than about rust.
My kin up north keeps most of their equipment in a series of pole barns. They have more $ tied up in equipment than I have in my retirement accounts.
   / Where do you park/store your tractor? #30
Kubota outside. Ten years old. Paint faded some. No rust.
Ford outside since 1959. Paint looks tired but so do I. No significant rust all things considered.
No that is not my wife. A maniquin I use as a scarecrow.
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
2014 Ford F-550 (A55973)
2014 Ford F-550...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
