Where can I safely lift from?
   / Where can I safely lift from? #11
On my tractor i jack it up from where the draw bar slides in. Its right in the center and is strong enough.
   / Where can I safely lift from? #12
Von, the only trouble with lifting in the center is that when you remove one wheel, the tractor will tilt the other direction. Maybe not a problem if you're expecting it, but can sure be a problem if you ain't./w3tcompact/icons/wink.gif
   / Where can I safely lift from? #13
Use the axle iself.
Once the correct tire (right/left?) is off the floor, I'd put a jack stand under both axles, then take the wheel off. I don't like leaving anything on a jack.
   / Where can I safely lift from? #14
While we're on the subject of lifting tractors, what type of jack do you all find most useful/safest? Floor Jack or Bottle Jack or ???
   / Where can I safely lift from? #15
I prefer my 5 ton floor jack to any bottle jack, 10x the contact with the floor. No way is a floor jack going to tip over. I also block car/truck/tractor up before going under, don't trust those $.50 seals on any hydraulic jack....
   / Where can I safely lift from? #16
Ford used to sell a jack for the N series that lifted all four corners of the tractor using the three point hitch.
   / Where can I safely lift from? #17
spence, while you're under there, put some grease on your mid PTO shaft.
   / Where can I safely lift from? #18
Anyone have any pictures of that jack? Sounds interesting.
   / Where can I safely lift from? #19
<font color=blue>Von, the only trouble with lifting in the center is that when you remove one wheel, the tractor will tilt the other direction. Maybe not a problem if you're expecting it, but can sure be a problem if you ain't.</font color=blue>
Maybe that would be a problem with loaded tires but that's how I do it without loaded tires and there's no problem. Also if you just put the bucket down flat on the floor and it's not in float the tractor can't tip, even with loaded tires but if you wanted to be extra safe after jacking slide some blocking under the tire that's staying on. But for my money, as Von said, it's dead center and a very solid place to jack from with a floor jack.
   / Where can I safely lift from? #20
www.yesterdaystractors.com. There is a guy in the 9N-2N-8N forum that has sales fliers for about every doo dad you could get for those tractors. He's kind of a N series John Miller III. ;)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2023 Kubota Z252KH-54 Zero Turn Mower (A55314)
2023 Kubota...
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
