Where can I find right-angle gearboxes?
/ Where can I find right-angle gearboxes? #1
jimgerken
Minnesota
John Deere 3720
Can you suggest sources of right-angle gearboxes for me to shop? I am looking for snowblower parts now, in preparation to build a blower in a month or so. I need a box of ratio 1:2 or 2:1, 90 degree, 2000 RPM input, 15HP max.
I will also be needing to put together at least one, and possibly two, PTO shafts with U-joints. Any suggestions for these parts will also be appreciated. Thanks!
/ Where can I find right-angle gearboxes? #2
Tr7 Surplus Center 1-800-488-3407. They don't have a web site. Pages 6 & 7 of their current catalog has gear boxes and reducers.
/ Where can I find right-angle gearboxes? #4
Granger seems to "have it all." Do a search for their site for an on-line catalog. You can also order a paper catalog on line. It also comes with a CD. It is excellent.
Mike
/ Where can I find right-angle gearboxes? #5
You may have to go to an industrial supplier in your area for a gear box of that size. There are three companies I know that make gear reducers, Morse, LinkBelt, and Dodge. I am sure there are others but when you get into the 15 HP size the choices are fewer and more expensive.
You should be able to find all the PTO shaft parts you want at your local tractor dealer or the Tractor Supply Company. Good luck.
Randy
/ Where can I find right-angle gearboxes? #6
jimgerken,
Keep in mind a 2:1 increaser will be a lot more expensive and heavy than a 1:2 reducer. You should be able to find a lot of 1:2 reducers in the 15hp range from all the sources mentioned.
Good luck,
Michael
I blew that part of my post where I wrote 1:2 or 2:1 reducer. I meant to say 1:1, or 2:1 reducer (input 2000, output 1000). Reduction is an option because there will also be a chain drive in the system. So, I can reduce in the box or on the chain, either way.
Thanks for the tips guys, I will check some of this out.
/ Where can I find right-angle gearboxes? #8
Try a tractor wrecking yard, or a scrap metal yad in the piddly little ones we have here theres plenty of them. Try looking for some industrial mowers they have lots of right angle boxes.
/ Where can I find right-angle gearboxes? #9
You can often find reduction gearboxes on ebay at good prices. They are usually pretty expensive if you buy them from the industrial suppliers.
Dave
/ Where can I find right-angle gearboxes? #10
I saw in your profile that you are from Minnesota-- a good farm state-- ckeck the implement dealers to see if they might have an old grain auger with a gearbox on it that you might be able to buy at junk price!! Pull the gearbox off, and haul the rest to the scrapyard-- could save you some bucks!! Could also try some farmers; you never know what they might have out in the back 40!!
/ Where can I find right-angle gearboxes? #11
I wonder about an automotive differential? Strip off the axel housing & you have your shaft. Also could use drive shaft.
WOW! You guys are full of good ideas. I will check some of these out. I am going to an industrial scrapyard later this week, I already checked at a local scrapyard, I am leaning toward a helical gear unit to handle the 2000 RPM speed but completly forgot about old grain auger boxes, and I like the auto differential idea too, will think about it. Thanks a bunch guys, somebody once said:
"The best way to get a good idea is to start with a whole bunch of ideas."
Automotive differentials: Assuming it is a standard diff, not a limited slip, if I pin one axle output shaft so it can't turn, does the other axle shaft spin twice as fast? Is it OK to run a differential in this mode for extended periods of time, assuming normal lubrication is present?
Thoughts: I find a 3:1 -- 3.8:1 differential, feed it 2000 rpm input, pin one axle so the other spins twice as fast, and fine tune the final rotor speed on my snowblower project with the chain and sprockets final drive.
/ Where can I find right-angle gearboxes? #14
Yes, if you lock up one side, you can use it the way you want to. Back when we had this board on Yqahoo, I posted how to use one to make a post hole digger.
Many chain trenchers use auto rear ends to power the digging chain.
In your application, the main consideration you need to make is installing a well calculated shear pin to protect the PTO.
/ Where can I find right-angle gearboxes? #16
Jim, There is a right angle gearbox on ebay #1770363533 starting at $8.00, has 1.25 shafts so its probably pretty strong. Not mine I just saw it.
Wally
/ Where can I find right-angle gearboxes? #17
I'm the guy who built one from a car rear end, complete with augur, if that's what you call a recipe.
There was a thread about doing it back just before Yahoo went from club to group, or whatever. I don't know if those threads can still be viewed.
/ Where can I find right-angle gearboxes? #18
you can purchase new right angle gearboxes at a good price from agri supply and ujoints and shafts. you can also purchase gear boxes, and componets from surplus center on the internet they are very reasonable on any thing they sell. hydraulics,lots of farm items.
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
