Where can I find a straight draw bar?
   / Where can I find a straight draw bar? #11
TSC has Cat II drawbars for $70 and Cat I for $35. They also sell drawbar locks (keeps the drawbar from spinning if you put a ball hitch on it for instance). That is much cheaper than you could buy the bar stock, machine off the ends and drill all the holes.
I believe he wants a draw bar that slides in under the tractor, not one for the three point.
Most commonly referred to as a swinging draw bar.
Op search for swing draw bar , you should come up with plenty of hits, just have to compare dimensions to what you have now.
   / Where can I find a straight draw bar? #13
Keep in mind that the drawbar length from the first u-joint to the pin and from the pin to the u-joint on the baler needs to be equal. That being said, is it possible to flip your drawbar end for end and get the proper height ? That may mean another hold in the bar to contain the tractor pin, but it may be possible to adapt it.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
2017 ford f-250 (A56858)
2017 ford f-250...
1997 FORD SERIES F-SERIES DUMP TRUCK (A57192)
1997 FORD SERIES...
2018 KENWORTH T270 SERVICE TRUCK (A57192)
2018 KENWORTH T270...
2009 Nissan Maxima Sedan (A55853)
2009 Nissan Maxima...
