Where can I find a straight draw bar?
   / Where can I find a straight draw bar? #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
Picked up a used baler and with the draw bar flipped over to the "low" setting it is too low. When I flip it over to the "high" setting the baler is level but I get driveline interference with the draw bar. I think with some adjustments on the baler hitch in combination with a straight bar , I'll be good.
   / Where can I find a straight draw bar? #2
It should be easy enough to fabricate, draw bar low then metal bracket bolted to it with ball at right height.
   / Where can I find a straight draw bar? #4
I would imagine you can find just about any type drawbar you need at Messicks.com. Thank goodness - I got and kept the one with my 2009 Kubota M6040.
Don't be overly shocked when you see the price. I would guess somewhere between - $140 to $150.
And unless you wrangle free shipping - mine is 1.25" thick x 2.75"wide x 22"long and weighs right around 24#.
   / Where can I find a straight draw bar? #5
Might be better off and cheaper to get just the piece of stock the diameter you need and go from there.
   / Where can I find a straight draw bar? #6
Yes - starting with a piece of stock that is 1.25" thick by whatever other dimensions you need may be a cheaper way to go. PROVIDED - you have a pretty hefty drill press to drill the holes you will need. I know I would not try drilling a 1" diameter hole thru 1.25" thick stock with my drill press. My draw bar has four holes - two are 1" and two are 0.75". That a pretty gritty task for the normal home drill press.
   / Where can I find a straight draw bar? #7
Correct me if I'm wrong but I think by looking at the baler hitch you could tell how strong you need to fabricate. I'm thinking the draw bar is probably way overkill in strength, so maybe a section of, say, 3" square bolted to draw bar grade 8 bolts ball in middle would be plenty strong enough.
Or maybe simply a stack of 1/2" x 3" flat steel bars...easy to drill.
   / Where can I find a straight draw bar? #8
I have a local steel/fab shop close by that I use for things of this nature. Maybe you have one around you could buy the stock from and have them drill them for you?
   / Where can I find a straight draw bar? #9
My local TSC (Tractor Supply Company) has several variants on generic, straight drawbars in inventory.
One size for subcompacts and larger ones for compact tractors.
   / Where can I find a straight draw bar? #10
TSC has Cat II drawbars for $70 and Cat I for $35. They also sell drawbar locks (keeps the drawbar from spinning if you put a ball hitch on it for instance). That is much cheaper than you could buy the bar stock, machine off the ends and drill all the holes.
2011 Chevrolet Malibu 2LT Sedan (A54815)
2011 Chevrolet...
14179 (A55788)
14179 (A55788)
Sterling AT (A55315)
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
