Where are the locations of any zerk fittings on a 2002 TC40?
   / Where are the locations of any zerk fittings on a 2002 TC40? #1
nickel plate
CA
2002 New Holland TC40S
They are easy to find on the 16LA loader, bucket grapple, front end and the one on the 3-point hitch angle adjustment crank but are there other zerks on the tractor that I have missed? This is a 12X12 manual transmission.
Attached the photo just to show my custom designed grapple that in itself has eight noticeable zerk fittings.
No grease zerks have yet been disclosed here on the TC40, 10 points for each TC40 zerk findings on the TC40 body. High score gets a well deserved TBN KUDO!
   / Where are the locations of any zerk fittings on a 2002 TC40? #3
Crawl around under the tractor and you'll find most of them.
This could be what I'm looking for but it is centralized around 2003 DA models, none of which are mine but it's worth a look-thanks seville009.
Iman-you a funny guy....
So, to date no actual hands-on zerk fittings grease monkeys on TBN?
   / Where are the locations of any zerk fittings on a 2002 TC40? #8
Climb under and have a look. The manual looks to be correct for my who-knows-when TC40DA, so as long as you have supersteer it will be the same.
I also have a zerk on the HST pedal pivot, the brake pedal pivot, and two on the manual height adjust on one three point arm.
James
   / Where are the locations of any zerk fittings on a 2002 TC40? #9
For load bearing pivots like the front axle (hardest zerk to find?), I try to take the load off with a hi-lift jack before greasing. That way the lube gets where it is needed.
TC-40D Lube Questions
   / Where are the locations of any zerk fittings on a 2002 TC40? #10
John Deere 6120E (A50323)
John Deere 6120E...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
Caterpillar CB-34 (A50120)
Caterpillar CB-34...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
20X8 SHIPPING CONTAINER (A52472)
20X8 SHIPPING...
