Where are the locations of any zerk fittings on a 2002 TC40?
   / Where are the locations of any zerk fittings on a 2002 TC40? #11
The front axle pivot area has 3, 1 in front and 2 behind. The tie rods each have one and so does the end of the steering ram. My right brake pedal pivot has one. Dont for get the 2 on the top link and 2 on the bevel box.
The loader is prety self explanatory how ever if you have a SSQA the vertical pins for that should have them also.
If you have a loader dont neglect the loader control joints. Those little suckers are over $300 to replace.
   / Where are the locations of any zerk fittings on a 2002 TC40? #12
Geeze - ruffdog. I thought my M6040 with grapple and rear blade had a lot of zerks.
   / Where are the locations of any zerk fittings on a 2002 TC40? #13
More Zerks, more grease, longer the tractor will live. Cheap chineasum crap you barely see any zerks .Thats one way of telling a well-engineered piece of equipment from a POS. 🍻
   / Where are the locations of any zerk fittings on a 2002 TC40? #14
That's nothing. I serviced a road grader once and it had 22 fittings on one of the front corners, the same on the other corner and I hadn't even got to the middle or wing plow yet.
NEW Woods 6ft Finish Mower (A55302)
NEW Woods 6ft...
2025 Spirit 48 48V 1000W All Terrain Electric bicycle (A55758)
2025 Spirit 48 48V...
Kifco B130 Water-Reel Irrigation Reel (NO LEAKS)(LIKE NEW) (A50775)
Kifco B130...
2007 Yamaha Rhino 660 (A55302)
2007 Yamaha Rhino...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
