Where are the locations of any zerk fittings on a 2002 TC40?
   / Where are the locations of any zerk fittings on a 2002 TC40? #11
The front axle pivot area has 3, 1 in front and 2 behind. The tie rods each have one and so does the end of the steering ram. My right brake pedal pivot has one. Dont for get the 2 on the top link and 2 on the bevel box.
The loader is prety self explanatory how ever if you have a SSQA the vertical pins for that should have them also.
If you have a loader dont neglect the loader control joints. Those little suckers are over $300 to replace.
   / Where are the locations of any zerk fittings on a 2002 TC40? #12
Geeze - ruffdog. I thought my M6040 with grapple and rear blade had a lot of zerks.
   / Where are the locations of any zerk fittings on a 2002 TC40? #13
More Zerks, more grease, longer the tractor will live. Cheap chineasum crap you barely see any zerks .Thats one way of telling a well-engineered piece of equipment from a POS. 🍻
   / Where are the locations of any zerk fittings on a 2002 TC40? #14
That's nothing. I serviced a road grader once and it had 22 fittings on one of the front corners, the same on the other corner and I hadn't even got to the middle or wing plow yet.
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2008 Hall 6'x20' Trailer (A53316)
2008 Hall 6'x20'...
Rears 1000 Gallon Orchard Sprayer (A53314)
Rears 1000 Gallon...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
