When will tractor manufacturers finally offer a front 3pt and implements for CUTs
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #32
This hasn't been mentioned but a lot of tractors--well, at least my Kubotas--have pto stubs on the front of the crankshaft. I recall years ago lots of hydraulic things used to be hooked to them. Can't recall exactly but maybe mowers as well as hydraulic things. Maybe front mowers?
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #33
I once considered adapting one of those Swisher mower decks to mount up front on my John Deere Gator 4x2. Use the winch to control deck height. It pushes a snow plow surprisingly well so it might work.
Not a three point attachment but seemed to work well in my mind.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #35
You guys are not looking hard enough, the front 3pt /pto offered by tractor manufacturers are supplied by the likes of Zuidberg and Laforge.
Zuidberg Frontline Systems B.V.
MK Martin also offers them. I would go Zuidberg.
Thanks for the link WilliamBos, I didn't find this manufacturer in my initial search. Just from browsing it looks like they make a ton of models for JD tractors.
   / When will tractor manufacturers finally offer a front 3pt and implements for CUTs #37
I know Mk Martin makes a front 3pt with a either clockwise or counterclockwise gear reduction kit to make the Mid-PTO reduce down to 540. They only make this for a few models unfortunately.
Even if I couldn't get front PTO setup with a 540 reduction, I could still see some uses for a front 3pt. Anybody how has ever tried to run a cultivator off a 3 point knows that this task is a P.I.T.A to try and keep the tractor straight and the cultivators out of the rows.
The 3 point looks like something like that might be easy enough to fabricate if one had a plasma cutter and good welder. As for the gear reduction PTO that might be a different story.
Those Vertrac tractors were similar to the old Toro Pro lawn tractor I used to work with. everything was front mounted and belt driven. I was always fabricating attachments out of the junk pile to make my job a little easier.
My uncle had a Farmall A, I think, that had a mid mount row cultivator that was raised and lowered by that weird midmount hydraulic arm they had, and my farmall cub had a belly mower that likewise was raised and lowered by the mid-"hydraulic" arm, but was powered by the rear PTO via a long belt and several pullies... Not fron mounts by any means, but way better thna rear mounts..
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
John Deere 6100D (A50120)
John Deere 6100D...
John Deere 1020 Tractor (RUNS) (A50774)
John Deere 1020...
