When tractor won't go into certain gears
   / When tractor won't go into certain gears #11
Okay guys, update. Got the PTO issue resolved, and now I'm ready to look at the low gear issue.
Here's what I know: the entire low range will not engage at all. The high range will engage. The PTO will run in either low or high range.
BTW, F350-2, I want to be sure we're talking about the same area. I'm talking about the open area that extends from just behind the engine to the back of the PTO area, and encompasses the gears, rear end, and PTO stuff. I dunno what you consider a lot of oil, but it drained over 11 gallons for sure!
So, any gurus out there that can tell me why I might not be getting the tractor into low range?
I found the password for my original F350 account. 485didriver, I believe we're talking about the same thing. I may have understated the amount of fluid. It's been a while since I changed mine. On my 485 the transmission takes gear oil and the "rearend/pto" area take hydraulic fluid. Two seperate systems.
Interesting. When I had the PTO shaft out, I could look look past the connection for the PTO and actually see some of the gears from the gearshift box area. Kinda had a semi partition between the two, but they're all connected. So from this one view I can see the rear axle gears, the PTO, and the gears from under the gearbox. Knowing this, I went ahead and put 90 weight gear oil in there. So far I've put two 5 gallon buckets, but it's only 2/3 full!! $120 of oil so far!!!:mad:
   / When tractor won't go into certain gears #13
The transmission and rear end case are the same oil sump. The hydraulic reservoir is above the rear end but a separate case.
That's definitely my setup, Galen. I wasn't sure if different year models were set up differently than mine, so was hesitant to say much more. So, gear oil WAS the proper oil for this, right? Any idea how many gallons it'll take?
Also, if you know, how big a chore is it to remove that hydraulic reservoir? Seems the only way to get to that pesky bolt I described earlier. Any idea(s)?
   / When tractor won't go into certain gears #15
It looks like if you took bolt out removed lock washer and put it back in you might have the clearance.
If that doesn't work get new bolt grind head down as needed to clear other bolt and swap out for repair put original back in when done.
tom
   / When tractor won't go into certain gears #16
485didriver - I was trying to say what Galen said. He did a much better job explaining the setup.
   / When tractor won't go into certain gears #17
Since we're talking about the old Mahindra Tractors so much lately. Here's the Wix filter #'s for the fuel filters: 33167 (Primary) and 33993 (Secondary). I believe they are the same for a 485DI, 575DI, 5005DI and 325DI.
   / When tractor won't go into certain gears #18
Hi There
1. Does that filter set work for my 4505DI?
2. Ya'll spooked me -cause I was changing my transmission and hydraulics - used hydraulic fluid in the main middel plu and the rear plug. 18 gallons and still a little short.
3. I am having trouble shifting my gears also - lost my low range and never had 4th. went to take the cover off last weekend (And I am alittle nervous to do this) and needed a 9/16" offset wrench for one bolt. What will I find when I lift the cover? Do I need to remove the gear shift levers first? What would be my typical thing to look for? I have a authentic bubba helper and 80 miles from the nearest dealer- already bought a gasket.
Michelle
Michelle,
How did you get that bolt out? The one that's directly beneath the hydraulic control bolt, I mean. This one:
And I was riding mine again today, same as yours: lost the entire low range, but don't have 4H either!! Keep me posted if you get a clue!!!! Any help for this, now that the request is in stereo?
   / When tractor won't go into certain gears #20
Yep
I have the same problem. No low range completely and no High 4th gear (8th).
Do you have a 4505?
You know these are remakes of an international tractor(dont know the model though)- what is their solution?
Yes that is the bolt - we looked saturday at 3 part stores, one hardware and wallmart.
I think what is needed is a 9/16" offset wrench. My Daddy taught me well. I have not procured and tried one yet.
The next step is to determine what surprise is causing the problems under the cover.
I feel something is loose or binding and judging from your same problems there is a trend here. Maybe one of these dealer smart guys can respond. My shop said they got rid of the 4505 books which really lit me up the other day.
Let me know what I need to know.
Thanks
Michelle
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
