When to plane rough cut lumber?
   / When to plane rough cut lumber? #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I just got a bench top planer. This question pertains to when to use it. I have some rough cut white oak planks. Most are a little over 1 inch in thickness. They were cut about a month ago and have been stacked on stickers in my basement since that time.
My plan is to make some built-in shelves out of them.
I know they need a lot longer to dry at this point.
But once they have dried sufficiently what is the timing of thickness planing them to their final (pre-sanding) dimension which will be around 3/4"? Should it be done well before I plan on building the shelves or right before I build them......of does the timing even matter once the rough cut boards are dried?
Any input much appreciated.
   / When to plane rough cut lumber? #2
Once dried, ready for use.
I guess the better way to ask the question is, once the planks are dry is it okay to plane them even if it will be a long time before I build with them?
   / When to plane rough cut lumber? #4
It really depends on the joinery you intend. If the shelves will be fitted into tight joints, it's best to have them at the finished dimensions and close to the approximate moisture content they will be when inside. If they are just resting on supports, far less critical to do so.
The wife and I just put in some live edge shelves on black pipe supports a couple of months ago, using some black walnut slabs. We cut the slabs, let them sit outside to loose the worst of the moisture. After about a week, we planed, stained, and installed the shelves over a weekend. Because the shelves aren't part of any joinery, no concern about final dimensions. And they were thick enough to be fairly resistant to warping, and have a ton of books sitting on them, holding them flat.
   / When to plane rough cut lumber? #5
I would invest in a moisture content meter...run a board through the planer a few times and see what the MC is...as long as it's less than 20% or so you're fine...any wetter I'd let it dry some more...
   / When to plane rough cut lumber? #6
Once they are fully dry and located in about the same humidity as where the finished product will be, you can thickness plane them and they should stay stable and not warp or twist. Do note that you will want to face plane the rough stock either on a jointer or using a planer sled on your planer before you thickness plane it.
   / When to plane rough cut lumber? #7
Yes,as long as boards are protected from light and moisture between planeing and finishing to prevent color change,,,unless you plan to stain before clear coating. To retain natural color you could plane in advance leaving boards a bit thick then plane to final dimension within a few weeks of finishing. I pull enough boards for project from stack as much in advance of planing as possible then lay them out individually so that if they are to warp,they do it before use rather than after in project. Depending on species and other factors,one board out of a certain number will twist,buckle or warp after unstacked.
   / When to plane rough cut lumber? #8
I never plane rough lumber until I am ready to build something. I agree with pine, a moisture meter is a great investment. Electromagnetic meters are the best, Pin types are good, but you have to drive the pins into the wood get a true reading.
   / When to plane rough cut lumber? #9
I just did 22 18 wheeler loads of cypress. Some was walnut and pecan, but not much. Some boards were 30" wide and 16' long. I was looking for places to put planer shavings. We had a large drum sander too. It was all dry. Stacked with strips for 7 years. It was at an old pre civil war plantation house. Had to plane some of it down to 5/8" and repair some siding on the house. Oh and I had to straight line rip it with a Skil saw, because it had bark on each side. I just clamped a straight 1x6 on it and ran the saw beside it.
   / When to plane rough cut lumber? #10
I agree, plane it just before using it, not before.
With a pin type meter, it's best to ck moisture content in a "fresh" cut off end, of a board.
SR
(2) Firestone 320/85R24 and (2) Galaxy 25x8.50-14 (A50120)
(2) Firestone...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2013 TOYOTA TUNDRA(INOPERABLE) (A52472)
2013 TOYOTA...
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
