Wheels??
/ Wheels?? #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
Has anyone tried turning the wheels around on their tractor to give it just a little wider stance????
/ Wheels?? #2
I do this on all tractor I sell. I notice you are a new member in Al. If you will give me a e-mail at jmf@centurytel.net I'll try to help you if your near by.
/ Wheels?? #3
Eddie, When I bought my 1301d, it already had the wheels reversed for a wider track. The info sheet that the dealer gave me said that it was safer to leave them this way. The only reason that I can think of for having them in the narrow configuration would be for cultivating narrow rows on fairly level ground.
/ Wheels?? #4
Yes, it is a common practice in the tractor world. That wider stance helps by making the tractor less tippy..
Soundguy
/ Wheels?? #5
Make sure you swap "side for side" to keep tread in right direction, assuming you have rice or ag. tires, and I would only do the rears as I don't think you gain enough on the front to compensate for the extra strain on the front end parts by having weight off-center.
/ Wheels?? #6
I think most of us do. Be sure to put right rear tire on the left side and vice versa to keep the treads in right direction......
/ Wheels??
Thanks, I planned to switch sides with them. Years ago we had an 8N ford that we would widen out to cultivate with and would switch sides with the back tires. I think I will try the front tires even if I only get a couple of inches extra width it will help in the trailer I haul it all. It is a car hauling trailer with an open center. Now I only have about an inch on the inside of each front tire. It's tied down good but it still worries me.
/ Wheels?? #8
As posted earlier, front end parts are very high and sometimes hard to find. Widening the front will cost you in the long run.
/ Wheels?? #9
Any chance of you retrofitting the trailer a little with some added on planking or sheet metal?
Soundguy
/ Wheels??
I got them turned around. I sure like the looks of it better like this.
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
More info coming soon (A61574)
More info coming...
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
