Traction Wheels locked ...
/ Wheels locked ... #1
The Tractor Man
Ford 861
Hi Folks ... I have a Ford 861 (Selectomatic Shift) ... I parked the tractor a couple months ago and haven't started it since ... Now it won't start ... I want to put it inside for the winter BUT the wheels do NOT roll freely ... They seem to go in opposite direction when I pull the tractor ... What am I doing wrong ? ... Thanks for any help ... John
/ Wheels locked ...
Thanks for replying ... I tried neutral and reverse and 1st and second gears ...
/ Wheels locked ... #5
Apparently there is something wrong with the shifting mechanism it should roll fine in neutral
have you checked to make sure there is plenty of oil in the transmission ?
/ Wheels locked ... #6
It has been 35+ years since I was around a select-o-speed and do not recall if they will shift into neutral without the engine running. Hopefully someone with a better memory will chime in.
/ Wheels locked ... #7
IIRC Ford select-o-speed trans has a release mechanism that enables tractor to be towed without sliding rear tires.
/ Wheels locked ...
Exactly. The transmission defaults to park when not running. Right side of the rear axle housing above the running board.
THANK YOU all for the replies ... I will check the one above today ... Is it a lever or what ? ...
/ Wheels locked ...
Thanks to everyone here ... I took a long shot and asked a 95 year old man down the road ... Said he had a "Select-O-Speed 861" like mine and still had the manual ... Here is what I found ... see attached ... I feel dumb ... John
/ Wheels locked ... #11
Hope you copied the manual or took photos of every page!
Hope I am around when 95 to share things with neighbors!
Frontier RC2060 5' 3-Pt Rotary Mower (A66408)
Frontier RC2060 5'...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
40ft High Cube Shipping Container (A64553)
40ft High Cube...
HD Bale Ring (A66408)
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
