Wheeled box blade-small
   / Wheeled box blade-small #1
raven1
Okatie, SC
KubotaL3400
New to this forum. Anyone know of a 5ft or 6ft box blade (3 pt cat 1) that has rear wheels to smoothe out the normal rise and dip associated with light grading. This is not a problem when I can load the box and make speed on a long driveway, but it is hard to get good flat grade when only lightly loading the scraper. Seems like a set of swivel wheels (similar to a bush hog) about 3 or 4 feet behind would help. Research finds heavy duty ones with hydraulics etc. Too expensive and I don't have the remotes. I need fixed height wheels. I'll control depth with 3 pt lift. Sound nuts?? Probably cheaper to convert one of my existing boxes, huh.
   / Wheeled box blade-small #2
You want a DRAG SCRAPER.
Quite a few companies make them, mostly in size Large.
Cammond makes compact Drag Scrapers in Oklahoma, in 4'-5'-6'-7' widths.
Cammond Drag Scrapers
Okatie....what a romantic name.
   / Wheeled box blade-small #3
:thumbsup: Welcome to TBN :thumbsup:
Use the search box at the top of the page, type in "Drag Scraper", you will get several threads with good info. I think there was a thread using trailer jacks for the height and angle adjustment.
I have a 6' Cammond box blade, it is well made and heavy duty.
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
