Wheeled box blade-small
   / Wheeled box blade-small #1
raven1
Okatie, SC
KubotaL3400
New to this forum. Anyone know of a 5ft or 6ft box blade (3 pt cat 1) that has rear wheels to smoothe out the normal rise and dip associated with light grading. This is not a problem when I can load the box and make speed on a long driveway, but it is hard to get good flat grade when only lightly loading the scraper. Seems like a set of swivel wheels (similar to a bush hog) about 3 or 4 feet behind would help. Research finds heavy duty ones with hydraulics etc. Too expensive and I don't have the remotes. I need fixed height wheels. I'll control depth with 3 pt lift. Sound nuts?? Probably cheaper to convert one of my existing boxes, huh.
   / Wheeled box blade-small #2
You want a DRAG SCRAPER.
Quite a few companies make them, mostly in size Large.
Cammond makes compact Drag Scrapers in Oklahoma, in 4'-5'-6'-7' widths.
Cammond Drag Scrapers
Okatie....what a romantic name.
   / Wheeled box blade-small #3
:thumbsup: Welcome to TBN :thumbsup:
Use the search box at the top of the page, type in "Drag Scraper", you will get several threads with good info. I think there was a thread using trailer jacks for the height and angle adjustment.
I have a 6' Cammond box blade, it is well made and heavy duty.
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
