Ballast Wheel weights
/ Wheel weights #11
Re: Wheel weights/Good buy!
Mark,
Yeah,... It's just that the "Smith system of measurement" uses "feet" that are 1/12th the length of conventional ones! /w3tcompact/icons/laugh.gif
Thanks for catching my typo... they can be fun to play with, though.
Let's see.. 180 lbs. per 1/3 cu. ft. -- 4x12x12(feet) = 576 cu. ft., x3=1728(3rds), x180(lbs. per 3rd)=371THOUSAND and 40 lbs.!!....PER TIRE!! (IF I did the math right)
Guess I better stick with just 1 weight per side /w3tcompact/icons/shocked.gif
Larry
( but a measly 3000 lbs. or so in my loader sure isn't gonna tip this baby over!!)
/ Wheel weights #12
Bird -
These 'Bota manuals seem to be a never-ending source of entertainment. /w3tcompact/icons/smile.gif
Although skimpy in many areas, it treats wheel weights and liquid ballast separately (see attachment).
Also, the workshop manual says specifically to not fill the front tires. Not that I was ever planning on doing that, but what do you suppose that is all about?
/ Wheel weights #13
Harv, that's a very similar page to my manual, but you've got 24" tires and I've only got 16" ones, so mine makes no mention of wheel weights. And a year or so ago, I wondered about the admonition against putting ballast in the front tires; right after I had filled mine with water and anti-freeze, and if I remember right (which you wouldn't want to bet on) someone on the forum (one of the Kubota dealers or mechanics) said something about binding gears if you operated it in 4WD on a hard surface, so I didn't worry about it. However, when I ripped a valve stem out of the right front wheel, pushing a brush pile, and lost all the liquid ballast out of that front tire, I took it out of the other one also.
Bird
/ Wheel weights #14
Harv,
Can't say if any of this info can be applied to 'Bota owning, but in my manual under Determing Maximum Front Ballast John Deere first cautions not to overload the tires and then says; To extend drivetrain life, and to avoid excessive soil compaction and rolling resistance, avoid ballasting for continuous full power operations at ground speeds below 4.4 mph. (or 7 km/h for you metric guys)
DFB
/ Wheel weights #15
Fred,
Not for nothing.... but don't you kinda get a "wobble" going top speed? How did you mount and space them on the wheel so they'd be somewhat balanced? I know we're talking a tractor tire here with "275lb." wheel weights and not an automobile tire with "2 oz." wheel weight... but it's seems a little <font color=red>dangerous...</font color=red> /w3tcompact/icons/crazy.gif
At least an "overpriced" factory designed wheel weight mounts somewhat symmetrical onto the wheel.
I'd love to see a picture of how these things are mounted. I'd had to see you hurt yourself.
/ Wheel weights #16
Harv,
I saw your attachment and looked up the same section in the Grand L owners' manual. Guess what? Same spec. 185 lbs per wheel maximum. I am guessing, but it must have something to do with the strength of the steel wheel itself or the torque loading on the bearings. The liquid ballast in the tires can go up to 585 lbs per tire, so it's not the raw weight!
Hmmm I wonder what the real story is...
John Bud
/ Wheel weights #17
I put a post in the Photos Forum on 12/06/2000 (B7100 - wheel weights) that shows the brackets I made to hold bar-bell weights on our B7100. They've been on the tractor since last fall with no problems. Through all the bouncing around and spinning of tires that happens in snow removal, nothing has loosened up. I run up and down the road between neighbors near top speed. The photo shows the set up for 2-25 lb weights per side. I use a longer pipe nipple to install 4-25 lb weights per side for most usage. The weights don't wobble or move. Best of all, the whole set up was easy to build and inexpensive. If you have larger wheels, you could probably go to 50 lb weight plates vs. 25 lb plates. I just didn't have room.
Bob Pence
/ Wheel weights #18
HARV,
THAT'S (5) 25# + (3) 50# BARBELL WEIGHTS TO BE EXACT. THEY EXTEND OUT PAST THE RIM 4". THEY HAVE BEEN ON THE TRACTOR OVER A YEAR AND I HAVE NEVER HIT OR BUMPED ANYTHING WITH THEM. ( I KNOW THEY ARE THERE AND OPERATE THE MACHINE WITH THAT IN MIND)
A 1/2" FLANGE PLATE WAS MADE WITH THRU HOLES FOR THE WHEEL STUDS. A 1" NUT WAS THEN RECESSED AND WELDED IN THE CENTER OF THE PLATE. THE WHEEL STUDS ARE THEN REMOVED, THE PLATE INSTALLED OVER THE STUDS AND HELD ON WITH THE WHEEL STUDS AND NUTS.
BECAUSE THE WEIGHTS HAVE A 1" BORE THEY SLIDE OVER THE 1" THREADED ROD NICELY AND ARE THEREFORE CENTERED.THE OUTSIDE NUT HOLDS ALL THE WEIGHTS ON. THEY HAVE NEVER MOVED NOR HAVE I EVER HAD TO TIGHTEN THEM.(NO WOBBLE!)
I USE TO HAVE A COUNTER WEIGHT ON THE 3PH BUT FOUND IT MORE TROUBLE THAN IT WAS WORTH WHEN WORKING BETWEEN TREES AND SMALL PLACES.
FRED
/ Wheel weights #19
Fred -
That sounds like quite a setup. I'm sure many of us would like to see a picture. /w3tcompact/icons/smile.gif
Thanks for the detailed explanation, but YOU DON'T HAVE TO SHOUT! /w3tcompact/icons/shocked.gif
Sorry -- that was meant to be humorous sarcasm about your all upper-case message. /w3tcompact/icons/blush.gif
/ Wheel weights #20
Fred,
You may make a believer out of me yet! /w3tcompact/icons/smile.gif
I had visions of these barbell weights "just plain bolted on" wherever they may fit on the wheel. Sounds like a pretty inexpensive setup.
Rear wheel weights (or loaded tires) add stability to a tractor, but I would still use some ballast on the 3-pt. hitch. Using a 3-pt ballast takes some stress off the front axle and tires and can actually "increase" your loader capacity. On a smaller wheelbase (compact) tractor, it's even more pronounced.
If you get a chance, post some pictures. I'd love to see them.
2015 Caterpillar 430F 4x4 Extendahoe Loader Backhoe (A60352)
2015 Caterpillar...
500 BBL FRAC TANK (A60736)
500 BBL FRAC TANK...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
CAT 930M (A58214)
CAT 930M (A58214)
SKLP SK-SYLJ100 Hand-Use Hydraulic Track Pin Press Machine (A60463)
SKLP SK-SYLJ100...
(INOP) 2001 DODGE RAM 1500 SINGLE CAB TRUCK (A59823)
(INOP) 2001 DODGE...
