Ballast wheel weights for L3000DT
/ wheel weights for L3000DT #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
HELLO TO ALL,
well i finished my wheel weights, and they are on the tractor. as you all know
KUBOTA parts are expensive, so i made my own. i used the HACKERS design, and
i bought 12, 25lb. weights from WALMART, at about $10.00 each. i made two plates
1/2in by 12in. diameter, drilled, and machined holes in them, then welded a 1in threaded
rod in the center. painted to match, and mounted on the tractor. then installed 6, 25lbs
on each side. i can tell a difference in the way it handles, and rides, and hopefully it will be
more stable when using the front end loader. i am still working on the grill guard project,
but this one was more important. also working on a canopy.
accordionman
william l. brown
/ wheel weights for L3000DT #2
William,
How about sharing some photos?
Randy
RANDY,
as soon as i get the film processed, i will try to post some pics.
i have never done this before, so i may need help, as well as the
instructions.
accordionman
william l. brown
2012 FORD F-550 SUPER DUTY (A63569)
2012 FORD F-550...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
