Ballast wheel weights 4320
/ wheel weights 4320 #1
dwmaster
North Dakota
JOHN Deere 4320
If I install 2 110 wheel weights will they extend beyond the edge of the rim or wheel? I want to stay flush with the outside of the tire. I move snow and I don,t want to worry about them hitting a car mirror when cleaning parking spots.
/ wheel weights 4320 #2
If you haven't already done so, I'd suggest loading your rears with calcium chloride water mix. I did that a year ago on my 4320's R4s (added 1000#) and had excellent traction for snow blading and front end loading. Cost about $200.
I was going to do that if the wheel weights were not enough. My loader isn't here yet so I can't test it out. I am going to attempt a 101" snow bucket so I'll need some counter weight besides the box blade. I run a 101" bucket on my skid steers and they also have a 2500 lb. rateing so it should worked. We got 5" of snow 3 days ago and it worked great with just the box blade.
/ wheel weights 4320 #4
If you are using a 101" bucket on a tractor that is 72" wide that leaves like
15" on each side of the tractor so you would not be that close,right??
minimax
My machine has bobcat style bucket atachment. I will be useing diferent width buckets depending on what I am doing. If I am backdraging apartment lots I would choose a narrower bucket to get between as many cars as I can. I also have a super scraper made by bobcat that is only 20" wide. I just don't want another thing to keep in mind when I'am out working in tight quarters. I have a few HPIM0519.JPG bobcats so I have quite a few buckets.
PALLET OF MISC (A63291)
PALLET OF MISC...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
(4) BUCKETS OF MISC PARTS (A63291)
(4) BUCKETS OF...
Willmar Fabrication 915 (A64119)
Willmar...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
