Wheel spacers for 2538
/ Wheel spacers for 2538 #1
Tee13
Mahindra 2538 HST Cab
I have a Mahindra 2538 cab, and it feels a little tippy. I'm looking to purchase some wheel spacers for the back but not sure how wide I could go. Also, aluminum or steel?
/ Wheel spacers for 2538 #2
Mahindra 2538
Cab Weight:3351 lbs
1520 kg
I recommend 2 X 3" wheel spacers. Steel spacers are likely to be much stronger than aluminum equivalents. I value peace of mind.
(I installed Bro Tec steel wheel spacers on my 1,800 pound Kubota BX)
If you have R1/agricultural tires on your Mahindra you may be able to choose between two wheel spreads. You may or may not be at the wider of the two options.
If you have R4/industrial tires wheel spacers are the way to go.
Thank you! I have industrial tires which is why I'm looking for spacers.
/ Wheel spacers for 2538 #4
Bro Tec has the widest selection of wheel spacers. I expect they know what TYM wheel spacers are the correct fit for your TYM badged-for-Mahindra model.
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
Turf Tiger Velocity Plus (A64557)
Turf Tiger...
PORTA POTTY (A68842)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
