Wheel Seal
/ Wheel Seal #1
Gizmo36
Platinum Member
East of Duewest S.C.
I have a wheel seal Leaking .How hard is it to pull the Hyd. cover and put it back on a 2210.Because I will have to pull the Hyd.cover and the PTO cover to fix the wheel seal.I don't know if I want to do it or pay the $50 an hour.That I don't have ,
/ Wheel Seal #2
I have never seen a 2210, but why do you need to pull the hydraulic cover?
/ Wheel Seal #3
None of that was necessary to replace the seal on my YM2000. Removed wheel, hub, seal cover and replaced. New gasket, seal and buttoned back up. Getting the hub off the axle was a major major pain........
/ Wheel Seal #4
Sometimes that hub won't come off and it's easier to just go ahead and remove the axle.
/ Wheel Seal
I thought I had to pull the axle.. But i may try to get the hub off .I thought it was all one piece. I order all the New gasket, seal for it .And if I do have to pull the Hyd. cover how hard is it to get back on.
/ Wheel Seal #6
Gizmo,you will have to drain housing,remove cover,pto shift rods,pto assm. differential lock shaft and fork and bull gear from axle.Axle and hub are one piece on 2210.Then remove end cap and axle can be removed from housing.This is probably not a job you want to tackle unless you have some experience on this type of repair.Also goes a lot easier with 2 people as cover is heavy and reinstalling axle in housing needs 2 sets of hands. 1 to hold gear in place and 1 to shove axle back in.I'm in SC also and if I can be of help,send me a pm.
/ Wheel Seal
I can always use some good help. Because I don't know what I am doing was just going to wing it.
/ Wheel Seal
tommyb thank you ,but it is 5 hours from were I am to were you are. I may come down that way one day. But I think i will try To do it. Can any one tell me how much Hyd.oil goes in a 2210. And does any one have the CD Manuel and do you like it. I got the book on my 1700 , But am think of getting the CD on the 2210.
/ Wheel Seal
Put the seals in the 2210 today was not that bad.The shift rods are hard if you have big hands like i do.Putting the differential lock sping in is hard .And it does take two to put the axle back in . Start at 7 AM and was done at 2 PM All but putting the tools up.The axle's on a 2210 would hold a 40 HP easy.
/ Wheel Seal #10
Did you take any pictures? Got to do this on my 2020. It would help to see in advance what I'm doing. Perhaps you could PM me with step by step instructions.
/ Wheel Seal
PM me your phone number and I will tell you how to do it. Just tell me what time to call you tomorrow. It ant that bad at all just need two people to do it. and you only need them for less then a hour.
2018 CAT D6TXL DOZER (A67714)
2018 CAT D6TXL...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2014 MACK PINNACLE CHU613 (A68134)
2014 MACK PINNACLE...
