WinterDeere
Super Member
- Joined
- Sep 6, 2011
- Messages
- 5,704
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
I've been dealing with the problem of wheel ruts at my shed entrance for too long. This was yesterday:
It's just the first 6 yards from the door going out, and this happens every year, as the sun always softens the frozen earth in this area. Yesterday was 9F - 19F, or something close to that, yet the area just outside this barn door was too soft with a bit of solar heating, to carry the load of the tractor.
My thinking is to pick up some 8' long concrete lintels or parking stops, and set them into the ground across this path, maybe 4" lintels on 8" spacings or 6" parking stops on 10" spacings. This will still allow me to grow grass here, like some of those concrete grid areas you see used in high traffic lawn areas:
I'm figuring an 8' wide lintel or barrier should be sufficient, lowering the soil pressure at least 4x - 6x by their length alone, but even more so because I'd excavate a bit deeper than the concrete objects and use cinder to level them, which spreads the load even more. Perhaps most importantly, the soil they're sitting on, 8" or 10" down, won't be daily warmed by the sun.
I found a photo of close to what I'm thinking, minus the fancy interlocking 2D array, I'd be doing just be a single row of "ribs":
Thoughts? Predictions of success or failure? Possible sources for cheap lintels or parking stops at 8' widths?
My other option is of course to just form and pour myself, which could be done in-place. But I'm thinking that with forming wood and rebar, the actual $$ saved is probably not worth all the effort, esp. since I'd have to hand mix or rent a mixer. Would like to hear others' thoughts on this, though.
