Wheel Motors
/ Wheel Motors #21
Don't know if it would work or not, however, when we had car hubs that wouldn't come off, we'd loosen the lug nuts a bit, then drive the car around the block. It would almost always pop the hub free. Just don't loosen them too much or you can damage the lug bolts. Anyhow, something to think about.
/ Wheel Motors
I noticed a picture of someones 422 hubs.. they look like they are little thicker. I am a little worried about putting to much pressure on mine with the wheel puller. Don't want to bend or warp them and create more problems. Great suggestion Moss, I will have to keep that one in mind as a last resort.
/ Wheel Motors #23
Personally, if you have put PBlaster and heat on it and are still can't get it loose, I'd go with with MossRoad's excellent shade tree suggestion before wailing on it with a wheel puller. You'll get impacts and stress to help break it free. Just don't have the lug nuts more than merely loose.
All the best,
Peter
/ Wheel Motors #24
Since heat makes things expand, have you tried CO2 to chill down the shaft and hub?
We used to put bearings in the freezer, and they slid right on the axle shaft, so there must have been some shrinkage there.
Bags of ice or whatever.
/ Wheel Motors
I'll try that trick too if it continues to give me trouble.. Thanks... J.J.
Hopefully installing my new garage door opener doesn't take up too much of my time this weekend. I hope the new tracks and motor fit right and I don't have to take it back and exchange it for another brand.. I wanted to spend my time working on old Red....
/ Wheel Motors
Thanks cqaigy2 ... I have already tried that but I will be trying that again along with some other suggestions .. I agree with Peter this machine has low hours but it is a 97... It's old and the hubs have never been off so it's going to take more of an effort to break them free..
/ Wheel Motors
OK installed my new garage door opener torsion springs etc .. So I finally had about an hour tonight to work on the PT.. Tried almost everything, heated until it smoked along with the wheel puller and banging on it with a large hammer, PB blaster.. I now have bad nicks in the outer edges of the disk from using a very thick steel rod and hammer.
This hub is really on there.. Starting to get a little annoyed.. Guess it's time to try Moss's suggestion and hook up the wheel, leave the castle nut slightly loose maybe an 1/8 of an inch and drive it around the property carefully.
Makes sense that it might pop off.. I just hope I don't do any other type of damage in the process. Think I will wait for Sat..
/ Wheel Motors
Must have missed that one... ??
/ Wheel Motors #31
Yeah, its something about heating up a part and melting bees wax on the seam, the wax is supposed to find its way into the parts and loosen them. It might be more for threaded parts.
/ Wheel Motors
I plan to give this bad boy my best shot a few more times this weekend, if I still can't free the hub..
I may just cut the shaft off and order a brand new motor.. Hopefully it won't come to that.. but time and rust has really frozen this part in place.
Thanks for all the advise from everyone...
/ Wheel Motors #33
It will come off. Don't destroy the motor over this. It will come off. Heat and wax a good combo, but you got to get the whole shaft hot enough for the wax to wick all the way. Bigger gear puller would be my solution.
/ Wheel Motors
I plan to stay with it.. I'll try the wax suggestion too. I have all day tomorrow to work on it. Thanks for the encouragement..
Called Terry this AM waiting on a price for a rebuild and for a new motor.. Would like to buy a new one and save the old one for a spare .. Depends on how much he wants. I know I could go to a hydraulic shop and see if I can get one cheaper but for the first one think I will stay with Power Trac and go from there..
/ Wheel Motors
I'll shoot a few in the morning ...
/ Wheel Motors
OK guys
Thanks for all of your help.. I hope the remaining three motors don't have to come off anytime soon That was a Bich .... I used a wheel puller and I had to other pullers for backup . That hub was really on there, heated it up and used the suggested wax candle trick then torqued it down on the wheel puller as far as it would go without snapping something..
The final step was the killer.. I used these to large chisels pictured that I bought yesterday to put on the extra pressure.. I wedged them down in-between the welded mount and the hub on the inside. You can see the mark on the wheel mount..
She wasn't coming off until I gave them both some hard taps with the hammer.. Finally it popped off.. Now to assess any damage to the hub and brake sprocket. I know I had to bend it somewhere with that kind of pressure..
Anyway now it's off and I can go to work taking off the hoses and the motor. While heating the shaft on the inside ( wax trick ) I hope didn't boil the oil or damage the hose's in any way.. It got pretty hot.. Everything looks OK on the surface..
Thanks for all of the advise on here .. :thumbsup:
/ Wheel Motors #38
Thanks for the pictures.
I didn't realize you were so close to me (I live west of Leesburg). I'd have loaned you my hydraulic wheel puller. It's supposed to exert 20 ton of pressure. We'll soon see as I have to pull all four wheels on my 425 to install the new wheel motors.
Glad you got it off.
/ Wheel Motors
I'm about 30 min's from there and drive into Leesburg every day for my business.. That's good to know, a fellow PT owner so close by.. May come in handy sometime for both of us .. ;) I live in Shannondale about 5 miles inside of Charlestown.... A hydraulic wheel puller, you should be good to go.. I think this one was rated at 10 ton's if I'm not mistaken..
/ Wheel Motors
Anyone recognize this motor ? Looks like Serial # 069-141-fp-c-tt-15-94 ..
Also I have the hose's tied upward but the oil is still draining out of the hose's. Put plastic bag over the ends with rubber bands still leaking. Am I going to have to bleed the system again when I reinstall the motor ? A few shots also my beat up hub. Nothing appears bent.
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
LOOK! (A63111)
LOOK! (A63111)
2015 CHEVROLET CAPRICE POLICE VEHICLE (A66091)
2015 CHEVROLET...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
