Wheel Lug Bolt (Stud) for JD2210
   / Wheel Lug Bolt (Stud) for JD2210 #1
scsi2005
Maryland, USA
JD 2210, 60c deck, 260 Backhoe, 210 loader, JD 1023E 60 in. deck
High everyone.
A quick question.
I bought wheel extenders for my JD2210 tractor and would like to use longer wheel lugs to secure them to the axle. I can not find the metric values. Is it a 10x1.25 or a 10x1.50?
And does anyone know where I get them that are about 35-40 mm long. I can cut them shorter after I add a lock nut to bolt.
Thanks in advance.
Steve
   / Wheel Lug Bolt (Stud) for JD2210 #2
According to JD parts it's NOT a Metric bolt: P/N M144698.
It's 7/16-20 with an overall length of 1.4"
How long, overall, do you need?
The only longer from JD is P/N M177386 1.7" overall
Auto parts store might be able to supply longer.
   / Wheel Lug Bolt (Stud) for JD2210 #3
Try matching diameter and thread pitch to DORMAN products catalog..... They have literally hundreds of "wheel" products in both SAE and metric....
Dale
Thank you both for the help. I just thought everything had gone metric lately.
Thanks again.
Steve
Just some info for you Dale,
The JD2210 has 7/16" lug bolts and not metric. Its pretty hard searching for spacers to match with 7/16".
I bought a $275.00 set from Bora which said they would fit my tractor but they supplied me with 12mm bolts and the holes were to big for the 7/16" and I destroyed one side by using my 7/16" bolts..
I am working with them to get this corrected at this time.
Thanks again.
Steve
Steve
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
40ft Shipping Container (A49461)
40ft Shipping...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
