Loader Wheel Horse Loader, install on Yanmar
   / Wheel Horse Loader, install on Yanmar #42
Try using some cutting oil and a slower speed on the bit and as much pressure as you can put on it. Once the cut starts you shouldn't have any problem going through it. Like winston1 said, a smaller bit to start will make it easier.
High speed and heat will dull a drill bit very quickly.
X-2 although not all titanium bits are created equal, the cheap china made ones that you find comes in a nice little case are hardly good for lightweight sheet metal,:cool: if these are the ones you have? stop waisting your time and go to your local NAPA and buy a couple good steel bits, it would still be best to use a cutting oil :thumbsup: I have 25 year old Bits , when they start to get a little dull I'll put them in my power bit sharpener that'll get back in shape,;) as far as I know the titanium bits cannot be re-sharpened,
I didn't know that, I was using High speed thinking .... not thinking:confused:
I was using a hand held drill, that stinks.. Going to TSC today, going to by me a drill press and some new bits.
Can't ever have to many toys.
I'll stop by NAPA and pick some up along with some cutting oil, thanks guys
   / Wheel Horse Loader, install on Yanmar #45
If you can get the part under a drill press, it will be a lot cheaper (and faster) to take it to someone who already has the equipment and just let them drill it. You'll like having a drill press, though, if you do much drilling into metal. This is an interesting thread, I've enjoyed watching the progress. You're coming along nicely, keep up the good work!
   / Wheel Horse Loader, install on Yanmar #46
I agree on the cheapo Ti coated bits...pretty junky. That said, I have resharpened them. It doesn't seem to make them any better or any worse. I have an old school sharpener that I got in a tool lot off ebay and is identical to this one. Sharpener Attachment - Drill Bit Sharpeners - Machining Supplies - Machining : Grainger Industrial Supply It works amazing well and will put a factory edge/point on even the hardest bits. In fact, I broke it out and used it to sharpen some of my best quality bits earlier this week.
   / Wheel Horse Loader, install on Yanmar #47
I've got a drill doctor that has paid for itself many times. Takes a bit of practice to use but it works. I tend to pick up pieces of scrap steel and I have come across some that took the edge off a drill bit in a few seconds. Don't have a clue as to what the make up of the steel was but it took a drill press, slow speed and a lot of pressure to cut a 3/8" hole through 1/2" flat piece. I had to use a glove to hold the bit so I could take it out of the drill press.:laughing:
Took ya'lls advice and stop by NAPA to pick up a $23 drill bit.
Picked up a drill press and was able to make some holes very easy.
Thanks.
Getting close to having the sub frame completed.
Two front mounts
Rear/Mid mount
I bolted the two front mounts on and the rear/mid mount.
Just have to make a bracket to bolt the two together so if I need to remove won't be such a chore.
Darn if I didn't get 1 of the front mounts off about an 1", going to have to move it but I'm too tired today, maybe Monday...
Lesson's learned so far:
Drill slow and used good bits for thick metal.
Don't use HF welding rods... I ran out of the one's I picked up at TSC
Tack weld your pieces, although I still didn't follow that and now going to have to chew through a bracket on the front mount to move it over.
Check hair often for fires
Got the 2 front mounts about finished.... I think :)
Just have to make couple of brackets to attach the rear/mid mount and 1 more bracket in the back. Hoping to have the loader bolted on soon.
Then have to make the front arms to mount to the very front of the tractor.
   / Wheel Horse Loader, install on Yanmar #50
How's the loader coming along? So far looks great:thumbsup:
2012 John Deere 624K (A55272)
2012 John Deere...
Golf cart (A56859)
Golf cart (A56859)
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
