What's your experience with a drag harrow?
   / What's your experience with a drag harrow? #1
Skyfair
Cheshire County, New Hampshire
Mahindra 1635 Shuttle
I have a quarter mile driveway with 1/2" bluestone. It was just redone last year, including finishing with a vibratory roller. Having just gotten through a NH winter, it is in reasonably good shape. However, there are areas where it has begun to rut under car and truck traffic, and there are some rough spots from plowing. I use a Meteor Pull Type snow blower behind my tractor, which I love and find very gentle on the gravel. However, there were several times when we were away and had the driveway cleared with a plow. My question is this - and point me to earlier threads if this has already been discussed - would a simple drag harrow work to smooth out the driveway? I'm sure I could make a harrow from chain link fence. A land plane or a landscape rake might be too aggressive for my needs. What has been your experience?
   / What's your experience with a drag harrow? #2
If you added some tires or something for weight you may scratch at it. If it’s packed down you’re going to need scarifiers in either a box blade or landscape plane IMO on your first run. A heavy backblade or rake may be ok too.
   / What's your experience with a drag harrow? #3
A chain harrow will not accomplish your task.
   / What's your experience with a drag harrow? #5
A Fuerst tine harrow will.
How about a spike harrow? Too coarse for a roadway?
p1710751rspikeharrowlifted-jpg.307656
   / What's your experience with a drag harrow? #6
I have a DIY drag harrow made from 6 foot wide chain link... Had about a 10 foot section, folded over in half and put a "T" post inside fold and attached chain to "T" post for towing,,, At rear of harrow I put 4 large rocks on lower half, folded top over and secured with tie wires....Its crude, it was a $0.00 investment and it manicures drive way just fine.... Now if I could just keep nephew slowed down I would not have to drag it as much....
   / What's your experience with a drag harrow? #7
Spiked Chain harrow is what I use on my driveway.Works great..
Does anyone have a source/solution for the "spiked" chain link fencing for DIY? Not sure what to do about DL Meisen's nephew...
   / What's your experience with a drag harrow? #9
   / What's your experience with a drag harrow? #10
The harrow should do fine as long as you engage the 3PH draft control. :)
I will see myself out now.
Lift Station Pumps (A49461)
Lift Station Pumps...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
