What's your experience with a drag harrow?
   / What's your experience with a drag harrow? #11
It really depends on how many fines have packed around your stones. If the driveway is hard packed, you will need something heavier and with teeth, not a drag harrow. But if the gravel is loose a chain harrow will work well..
   / What's your experience with a drag harrow? #12
jyoutz says it plain and simple. The more damage you are trying to correct - the heavier implement you will need OR more passed will be required with a lighter implement. If the implement is TOO light - you will soon see that continued use is next to useless. A toothed drag harrow will probably not correct your situation.
I have a Land Pride - land plane grading scraper with scarifiers. I uses it on the potholes, ruts, wash outs - etc. It works fabulously and requires little to no previous experience. Scarifiers are necessary to scuff up the bottom of potholes, etc so they incorporate with the new material dragged over them.
My driveway is a mile long and started out with a surface layer of pit run, crusher run,,,whatever you want to call it. Over the years - silt, sand & volcanic ash have been added - via our SW winds. I had my driveway constructed in 1982.
When our area dries out - after spring breakup - the driveway hardens like concrete. It takes my heavy LPGS to repair any damage. OR my heavy duty rear blade. Anything less just bounces along behind the tractor.
Another point - only grade up those areas that truly need repairs. Once the driveway is crowned and packed - leave it alone until repairs are needed.
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
yellow ball Trailer (A56859)
yellow ball...
