What's your diesel engine oil?
   / What's your diesel engine oil? #1
Rob-D
Catskills
John Deere 3320
I'm thinking of running Mobil 1, 0W-40 oil in my Deere. I'm presently running it in my Subaru Outback with good results. I live in the mountains of upstate NY and we get very cold weather here, well below zero although not in the last couple of years.
What I have found in my cars is that 10W-30 gives better fuel mileage but I like the 40 for hotter temps in the summer.
   / What's your diesel engine oil? #2
make sure you use a diesel rated oil; regular Mobil One is not for diesels.
According to the bottle it says,"Approved for use and exceeds warranty requirements for gasoline,turbocharged and diesel engines...."
   / What's your diesel engine oil? #4
Mobil 1 carries a CF rating, IIRC. I *think* (too lazy to call up the API.org website) it is for non-turbo diesels and higher sulfur fuels. Should be OK.
   / What's your diesel engine oil? #5
"What's your diesel engine oil?"
I run Texas Refinery's Moly Pro-Spec III 15W/40 in all my ag tractors and in my on road diesel trucks. I'll probably be buying a new medium duty truck later next year and will have to run Moly Pro-Spec IV 15W/40 in it because it will need a CJ-4 rated oil.
If your going to use Mobil I would suggest using their Delvac and not Mobil "1". The Delvac is their diesel line of oil.
   / What's your diesel engine oil? #6
Presently using the factory 10W-30 oil. At first change I will go to 5W-40 Shell Rotella Syn oil.
   / What's your diesel engine oil? #7
I run Rotella Syn in Winter and Rotella dino in summer.
Bob
   / What's your diesel engine oil? #8
I changed to Rotella 5w -40 late summer 2005. I live in the New York area and during the summer months I dont think it gives me the protection I need. It has been great for the winter, with starting being a lot easier. Even though I dont do the hours to make full use of the synthetic I was thinking of switching to a 10w -40 for the summer and then back to the 5 w 40 for the winter.
   / What's your diesel engine oil? #9
Doc_Bob - I'm just curious. Why don't you just run the synthetic all year? I understand you probably run it in the winter for the lower cold viscosity but why not all year.
   / What's your diesel engine oil? #10
Good question. I figure the oils dino vs synthetics are all so good that why spend the money in the summer for syn when dino will do just as well??? I am not going for extended drain intervals (I use Mobil 1 in my cars).
I will get in trouble for saying this, but dino vs syn in terms of longevity for the engine simply does not apply in my situation. I am looking for improved flow in cold weather on the tractor with syn. If I get 200-300 hours a year on my tractor, that would be great. Since NH says to change the oil every 300 hours, I expect changing oil and filter twice a year, after about 200 hrs in summer on dino, and 100 hr in winter on syn.
Bob
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
Towable Diesel Tank (A53421)
Towable Diesel...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55218)
New Holland 1412...
