What's your diesel engine oil?
   / What's your diesel engine oil? #1
Rob-D
Catskills
John Deere 3320
I'm thinking of running Mobil 1, 0W-40 oil in my Deere. I'm presently running it in my Subaru Outback with good results. I live in the mountains of upstate NY and we get very cold weather here, well below zero although not in the last couple of years.
What I have found in my cars is that 10W-30 gives better fuel mileage but I like the 40 for hotter temps in the summer.
   / What's your diesel engine oil? #2
make sure you use a diesel rated oil; regular Mobil One is not for diesels.
According to the bottle it says,"Approved for use and exceeds warranty requirements for gasoline,turbocharged and diesel engines...."
   / What's your diesel engine oil? #4
Mobil 1 carries a CF rating, IIRC. I *think* (too lazy to call up the API.org website) it is for non-turbo diesels and higher sulfur fuels. Should be OK.
   / What's your diesel engine oil? #5
"What's your diesel engine oil?"
I run Texas Refinery's Moly Pro-Spec III 15W/40 in all my ag tractors and in my on road diesel trucks. I'll probably be buying a new medium duty truck later next year and will have to run Moly Pro-Spec IV 15W/40 in it because it will need a CJ-4 rated oil.
If your going to use Mobil I would suggest using their Delvac and not Mobil "1". The Delvac is their diesel line of oil.
   / What's your diesel engine oil? #6
Presently using the factory 10W-30 oil. At first change I will go to 5W-40 Shell Rotella Syn oil.
   / What's your diesel engine oil? #7
I run Rotella Syn in Winter and Rotella dino in summer.
Bob
   / What's your diesel engine oil? #8
I changed to Rotella 5w -40 late summer 2005. I live in the New York area and during the summer months I dont think it gives me the protection I need. It has been great for the winter, with starting being a lot easier. Even though I dont do the hours to make full use of the synthetic I was thinking of switching to a 10w -40 for the summer and then back to the 5 w 40 for the winter.
   / What's your diesel engine oil? #9
Doc_Bob - I'm just curious. Why don't you just run the synthetic all year? I understand you probably run it in the winter for the lower cold viscosity but why not all year.
   / What's your diesel engine oil? #10
Good question. I figure the oils dino vs synthetics are all so good that why spend the money in the summer for syn when dino will do just as well??? I am not going for extended drain intervals (I use Mobil 1 in my cars).
I will get in trouble for saying this, but dino vs syn in terms of longevity for the engine simply does not apply in my situation. I am looking for improved flow in cold weather on the tractor with syn. If I get 200-300 hours a year on my tractor, that would be great. Since NH says to change the oil every 300 hours, I expect changing oil and filter twice a year, after about 200 hrs in summer on dino, and 100 hr in winter on syn.
Bob
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
