What's your average mpg?
   / What's your average mpg? #161
I guess I don't care enough about what my actual mpg really is, but the once or twice I did roughly check mine over the course of a tank, they were always closer than the finance department required.
True, if i cared about milage I wouldn't buy a truck and I'd still be driving my fusion at 28mpg. I wouldn't mind better with my truck but whatever...
Sent from my SM-S901U using TractorByNet mobile app
   / What's your average mpg? #162
I care about mileage. A lot. But I haven't found anything that will haul or carry a lot of weight and still get 30 mpg. So I have to own trucks.
   / What's your average mpg? #163
   / What's your average mpg? #164
My Ram 3500 gets such great mileage that I added a 46 gallon auxiliary tank to its factory 74 gallons.
It generally gets between 5 and 10 mpg depending on what it's towing. That's 98% highway, with a little Interstate every now and then.
   / What's your average mpg? #165
Diesel, stock? What are you towing and all mountains? That's the lowest I've ever heard of if it's a diesel, and I know quite a few that hotshot or haul cars with 3500 Rams and never get below 12.
Sent from my SM-S921U using TractorByNet mobile app
   / What's your average mpg? #166
Yep, all stock (except for tires, headlights, etc.). Towing varies between different trailers and loads, from about 8,000 to 25,000 lbs.
It's not all mountain roads, but I have no choice but to drive them coming or going here in the Rockies. Still, one of the lowest mpg averages was coming back from Reno, NV, and on that trip only about 15% of the 1,025 mile drive was dealing with longer and steeper grades. That was also at a full 39,000 GCVWR, maybe a bit over.
It's not uncommon to see the gauge read 25 gallons per hour being used, and I suspect that it's all the injectors can flow as I've never seen that number exceeded.
Another thing that may factor in is that I hand calculate all fill-ups rather than pick occasional nice numbers seen on the Lie-O-Meter to suit the argument. Plus I tend to drive a bit on the fast side, so just passing someone on a 2-laner puts a noticeable dent in the average numbers.
   / What's your average mpg? #167
2024 GMC Yukon 3.0 Duramax - 24 mpg combined, >30 mpg on the freeway, main vehicle for trips
2024 GMC 3500HD 6.6 Duramax - 12 mpg combined, mainly used for towing
2025 Chevrolet Tahoe 6.2L - 16 mpg combined, mainly used for local runs (wife's vehicle)
   / What's your average mpg? #168
2014 Subaru Forester 29.6 mpg (wife's)
2019 Toyota Tundra 16.7 mpg (mine)
Both used for short trips
   / What's your average mpg? #169
The meter on the dash of my F250 (6.2L gasser) has said 13.2 since the day I bought it over 10 years ago. Doesn't seem to matter if I'm running empty, loaded or towing. Never cared enough to calculate it at the pump.
   / What's your average mpg? #170
I track my F250 6.2L, and over 10 years my overall average is exactly 12 mpg. The trip meter is usually within 0.5 mpg between fill ups.
Towing 8k and up I range from 8 to 9 mpg, and lighter towing around 10.
CAT Chassis Only (A59076)
CAT Chassis Only...
1454 (A57192)
1454 (A57192)
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
