What's you most useful cheap tractor tool under 50.00?
   / What's you most useful cheap tractor tool under 50.00? #21
Way Cool!! Post pictures if you have any, please.
Sorry never took any pictures and have up graded to a mini ex with a couple of different buckets{1 is a ditching bucket}.
I made the blade fit the BH so I could even out spots around our ponds and also get into rough areas. It worked very well, I used it quite a bit.
   / What's you most useful cheap tractor tool under 50.00? #22
   / What's you most useful cheap tractor tool under 50.00? #25
Used dirt Scoop, 30" that I ended up tearing the pan up on. Took a few hours and made a new thicker pan for it, and it has done wonders since.
David from jax
Hmm, as I look at this one, I've decided it will not work.
T-post puller claw - Google Patent Search
As with mine, you slide it on upside down. That way the pull makes it tighten. On his as shown in the picture, straight up pull will simply lift the tool off the t-post. I would not think he'd "angle" enough to grab the post.
   / What's you most useful cheap tractor tool under 50.00? #27
Just because it's patented, it doesn't mean it will work. :) Also, if it's patented it doesn't mean you'll make money. It means that you can prevent somebody else from making money on your idea/design. In return, the information is out in the public domain, and eventually patents will expire so that anybody can make money on those ideas.
Crazy. ;)
   / What's you most useful cheap tractor tool under 50.00? #28
Here is my version of something like that.
   / What's you most useful cheap tractor tool under 50.00? #29
This right here.
Takeuchi TB016 (A53317)
Takeuchi TB016...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
