What's wrong with this picture?
/ What's wrong with this picture? #1
DJLX
East TN
JD 2210
What\'s wrong with this picture?
I got the new longer PTO shaft put together for my tiller (previuosly Need PTO Driveline help). It works-no problem but I did something dumb. Can you see it in this picture?
/ What's wrong with this picture? #2
Re: What\'s wrong with this picture?
65 other people couldnt or didnt say they could, so I will be the brave one.
50% sure you stretched your antispin chain when you lift 3pt all the way?
if not that shaft is backwards?
/ What's wrong with this picture? #5
I think you should have used a fill-flash, for you have such a contrast from the bright sunlit areas to the shadows.
/ What's wrong with this picture? #6
<font color="blue">I think you should have used a fill-flash, </font>
After reading Gatoboy's reply, I would have to say it looks like there is more than one correct answer to your question. /forums/images/graemlins/grin.gif
My eyes say Gatorboy is right...don't have a clue as to what the other right answer(s) might be... /forums/images/graemlins/blush.gif
/ What's wrong with this picture? #7
Obviously that tiller is on the wrong tractor and I would greatly appreciate it if you would carefully place it behind my tractor where it belongs /forums/images/graemlins/smile.gif
Yup it wasn't a trick question as I'm not smart enough for that. When I raised the tiller the antispin chain did break. I didn't notice it until after I had tilled the neighbors garden. The clip and s hook were all straighted out- I'm surrprised it was still dangling from the shaft.
/ What's wrong with this picture? #9
Dang, I was going to say it was to shiny and needed to be scratched up a little.
Steve /forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif
/ What's wrong with this picture? #10
I was going to say the Camera was Drunk
/ What's wrong with this picture? #11
The driveline looks to be installed backwards. If that is the case and it is a radial pin style slipclutch, it won't slip. Ooo /forums/images/graemlins/shocked.gifps!
Is it possibly to have a pto shaft in backwards? Does it make a difference whether the outside shaft vs inside is towards the tractor or towards the implement? Also the outer plastic protector looks identical except for the tubes-one being bigger that the other. The clutch goes at the implement end and the locking spline dohickey at the tractor end.
/ What's wrong with this picture? #13
The majority of implements have an 1 3/8" 6 spline input shaft. Your JD's PTO shaft has the same dimensions. Therefore in some cases it is possible to install a driveline backwards. /forums/images/graemlins/confused.gif From your response it sounds like you have it pr /forums/images/graemlins/grin.gifperly installed. As long as the clutch or shearbolt yoke is installed on the implement side your ready to play!
/ What's wrong with this picture? #14
wrong color on the tractor.........sorry could not resist!
/ What's wrong with this picture? #15
Can't say for sure but it looks like you have a screw in your back tire???
murph /forums/images/graemlins/smirk.gif
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
Dirt Dog 3PBU Hay Unroller (A65579)
Dirt Dog 3PBU Hay...
Continental Cargo 24' Enclosed Trailer (A66285)
Continental Cargo...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
