What's wrong with this picture?
/ What's wrong with this picture? #1
DJLX
East TN
JD 2210
What\'s wrong with this picture?
I got the new longer PTO shaft put together for my tiller (previuosly Need PTO Driveline help). It works-no problem but I did something dumb. Can you see it in this picture?
/ What's wrong with this picture? #2
Re: What\'s wrong with this picture?
65 other people couldnt or didnt say they could, so I will be the brave one.
50% sure you stretched your antispin chain when you lift 3pt all the way?
if not that shaft is backwards?
/ What's wrong with this picture? #5
I think you should have used a fill-flash, for you have such a contrast from the bright sunlit areas to the shadows.
/ What's wrong with this picture? #6
<font color="blue">I think you should have used a fill-flash, </font>
After reading Gatoboy's reply, I would have to say it looks like there is more than one correct answer to your question. /forums/images/graemlins/grin.gif
My eyes say Gatorboy is right...don't have a clue as to what the other right answer(s) might be... /forums/images/graemlins/blush.gif
/ What's wrong with this picture? #7
Obviously that tiller is on the wrong tractor and I would greatly appreciate it if you would carefully place it behind my tractor where it belongs /forums/images/graemlins/smile.gif
Yup it wasn't a trick question as I'm not smart enough for that. When I raised the tiller the antispin chain did break. I didn't notice it until after I had tilled the neighbors garden. The clip and s hook were all straighted out- I'm surrprised it was still dangling from the shaft.
/ What's wrong with this picture? #9
Dang, I was going to say it was to shiny and needed to be scratched up a little.
Steve /forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif
/ What's wrong with this picture? #10
I was going to say the Camera was Drunk
/ What's wrong with this picture? #11
The driveline looks to be installed backwards. If that is the case and it is a radial pin style slipclutch, it won't slip. Ooo /forums/images/graemlins/shocked.gifps!
Is it possibly to have a pto shaft in backwards? Does it make a difference whether the outside shaft vs inside is towards the tractor or towards the implement? Also the outer plastic protector looks identical except for the tubes-one being bigger that the other. The clutch goes at the implement end and the locking spline dohickey at the tractor end.
/ What's wrong with this picture? #13
The majority of implements have an 1 3/8" 6 spline input shaft. Your JD's PTO shaft has the same dimensions. Therefore in some cases it is possible to install a driveline backwards. /forums/images/graemlins/confused.gif From your response it sounds like you have it pr /forums/images/graemlins/grin.gifperly installed. As long as the clutch or shearbolt yoke is installed on the implement side your ready to play!
/ What's wrong with this picture? #14
wrong color on the tractor.........sorry could not resist!
/ What's wrong with this picture? #15
Can't say for sure but it looks like you have a screw in your back tire???
murph /forums/images/graemlins/smirk.gif
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
