Whats this?
   / Whats this? #1
Tractorguy24
BC, Canada
The cap on this old metal jerry gas can has a rubber hose coming off it. What is that supposed to do?
   / Whats this? #2
With the valve I would say it would be pressurized and it would empty thru other fitting
   / Whats this? #4
Portable gas tank for test-running carbureted engines? Pressurize to a few pounds for pressure feed without needing a fuel pump.
Maybe to feed an oil stove or heater?
Bruce
   / Whats this?
Thats a possibility
But why the rubber hose inside the can:confused:
   / Whats this? #7
Is it rigged up for an outboard Motor? Just a guess.
That was my guess too...some also used a inline primer bulb to get fuel up and flowing.
   / Whats this? #8
The jerry can adapter for the gasoline military tent heater looked just like that. the heater has a quick connector on it that connected to that fitting and the tank was set in a cradle to hold it upside down for use. Only seen one used once back in the middle 80's That was the night that the battalion commander's tent burnt to the ground. We were never allowed to use them again.
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
