what's the same as a jd5303
   / what's the same as a jd5303 #1
tedder
Prague OK
Kioti DK35
I want to upgrade to a 55 hp pto tractor and thought you guys would have some ideas as to what mahindra would be the same. thanks :confused:
   / what's the same as a jd5303 #2
I would say a 6000 would be in that category. I used to have one and loved it. I think they may have changed them to 6025 now but still worth a look.
   / what's the same as a jd5303 #3
The 6500 has 57 pto hp
The 6520 has 55 pto hp
These are some good tractors, the 6520 is a little more on the deluxe end.
Good luck with you search.
   / what's the same as a jd5303 #4
tedder,
If you are looking for a 2WD tractor the Mahindra 6025 is only 49 HP but it is about 800 lbs heavier than the jd5303, the other option would be the 6500 2WD, which is a real close match to the JD. In 4WD the 6500, 6530, and the 6520. These tractors are all a good bit heavier than thier JD counterpart, but that should be a good thing. These 4WD's also are shuttle shift transmissions which is optional on the JD. Check them out at mahindrausa.com, and have fun tractor shopping.
   / what's the same as a jd5303 #5
Tedder,
The JD 5303 has a three cylinder engine. All the Mahindra tractors near that horsepower (mentioned in the posts above) are four cylinder engines.
hugs, Brandi
thanks everyone, i have a dealer in okc that i want to visit. the biggest difference i see between the jd5303 with fwd is the weight m is heavier. :)
   / what's the same as a jd5303 #7
What I like about the 00 series tractors is how simple they are. Easy to work on and easy to diagnose. If you're looking for a no frills work horse check out the 00 series 4wd.
I have the 6000 4wd and have done some quite hefty chores for a 60 hp tractor!
I was leaning towards the 6500 with 4wd. Does anyone have idea what I should expect to pay for one with loader? Just want to have some idea before I visit the dealer. Thanks for all the input.
   / what's the same as a jd5303 #9
Hi
Like Brandi says the Deere 5303 engine is a 3 cylinder. It has about 15% less power than the 6500. If your need a 4wd, get the 6500. I have one and it performs well. A good price with skid steer loader (I ordered the skid steer bucket from the dealer and forks and later a root rake - all skid steer) would be around $25 k plus or minus. Some dealers throw in this or that. I would pay a little extra if needed to make the deal with a dealer with a jam-up service department (I did this). Both the JD 5303 and Mah 6500 are made in India. The 6500 is also a much heaver and stouter tractor (look at the loader mountings, rear 3 pont hitch and axles). I was a Deere person before I bought Mahindra. I almost bought a 25 series Deere last year.
My input.
Michelle
Thanks Michelle, I'm going to visit the Mahidra dealer in OKC this Sat. 25K with FEL sounds about right. Tedder
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
