what's the same as a jd5303
   / what's the same as a jd5303 #1
tedder
Prague OK
Kioti DK35
I want to upgrade to a 55 hp pto tractor and thought you guys would have some ideas as to what mahindra would be the same. thanks :confused:
   / what's the same as a jd5303 #2
I would say a 6000 would be in that category. I used to have one and loved it. I think they may have changed them to 6025 now but still worth a look.
   / what's the same as a jd5303 #3
The 6500 has 57 pto hp
The 6520 has 55 pto hp
These are some good tractors, the 6520 is a little more on the deluxe end.
Good luck with you search.
   / what's the same as a jd5303 #4
tedder,
If you are looking for a 2WD tractor the Mahindra 6025 is only 49 HP but it is about 800 lbs heavier than the jd5303, the other option would be the 6500 2WD, which is a real close match to the JD. In 4WD the 6500, 6530, and the 6520. These tractors are all a good bit heavier than thier JD counterpart, but that should be a good thing. These 4WD's also are shuttle shift transmissions which is optional on the JD. Check them out at mahindrausa.com, and have fun tractor shopping.
   / what's the same as a jd5303 #5
Tedder,
The JD 5303 has a three cylinder engine. All the Mahindra tractors near that horsepower (mentioned in the posts above) are four cylinder engines.
hugs, Brandi
thanks everyone, i have a dealer in okc that i want to visit. the biggest difference i see between the jd5303 with fwd is the weight m is heavier. :)
   / what's the same as a jd5303 #7
What I like about the 00 series tractors is how simple they are. Easy to work on and easy to diagnose. If you're looking for a no frills work horse check out the 00 series 4wd.
I have the 6000 4wd and have done some quite hefty chores for a 60 hp tractor!
I was leaning towards the 6500 with 4wd. Does anyone have idea what I should expect to pay for one with loader? Just want to have some idea before I visit the dealer. Thanks for all the input.
   / what's the same as a jd5303 #9
Hi
Like Brandi says the Deere 5303 engine is a 3 cylinder. It has about 15% less power than the 6500. If your need a 4wd, get the 6500. I have one and it performs well. A good price with skid steer loader (I ordered the skid steer bucket from the dealer and forks and later a root rake - all skid steer) would be around $25 k plus or minus. Some dealers throw in this or that. I would pay a little extra if needed to make the deal with a dealer with a jam-up service department (I did this). Both the JD 5303 and Mah 6500 are made in India. The 6500 is also a much heaver and stouter tractor (look at the loader mountings, rear 3 pont hitch and axles). I was a Deere person before I bought Mahindra. I almost bought a 25 series Deere last year.
My input.
Michelle
Thanks Michelle, I'm going to visit the Mahidra dealer in OKC this Sat. 25K with FEL sounds about right. Tedder
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
2022 PETERBILT 579 DAY CAB (A50854)
2022 PETERBILT 579...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
