What's the right attachment
/ What's the right attachment #1
PaulieD
Upstate NY (Adirondacks)
New Holland Boomer 35
What\'s the right attachment
I'm new to tractoring and need some advice on the best implements to use for some projects I have lined up. I have approximately 10 acres of flat non-rocky meadow. In this area I would like to plant 150 Christmas trees, a couple of acres of corn, a couple of small patches 0.5 acres each of clover, and 0.5 acres of pumpkins. I also need to clean up my yard. The well driller did some inadvertent and expected damage, and I need to clear it up.
I'm thinking about a tiller, but I'm afraid the boss, (otherwise known as my bride) is going to panic when she finds out what I need to spend. I've also considered a two or three bottom plow, a box blade, and a disk harrow, or a combination of these items.
I own a TC 30 standard transmission.
Any advice you guys might offer would be appreciated.
Thanks,
Paul
/ What's the right attachment #2
Re: What\'s the right attachment
A tiller would be great for much of that, a post hole digger is great for planting that many trees. A good box blade with rippers would do many of your jobs and more. Cheaper option for the tiller would be disk plows, you would just need to make more passes and it won't be as smooth as a tiller would leave it. Your tractor will operate just about anything you'll need. The owner's manual should specify the sizes of implements you can use. For the most part, you can handle 6' stuff without problems and some larger. John
/ What's the right attachment #3
I Just purchased a PHD w/9" auger from Northern Tool for $565 delivered. Would this price make your bride panic? If not, then I would order one. I think they are still on sale.
/ What's the right attachment #4
Put her to digging the holes while you drag the trees in and she will go for it.
Unless of course she puts you in charge of holes and finds out how much fun driving the tractor is. /forums/images/graemlins/ooo.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
/ What's the right attachment #5
I'm guessing that your trees will be seedlings...now this attachment is not tractor operated, but it is the best tool for seedlings on the market and costs about $50-$75 depending on what you order...with this tool I can plant 3000-5000 seedlings a day, depending on soil conditions /forums/images/graemlins/cool.gif
HOEDAD seedling planter
Thanks for all the help.
Gary, you were right about the seedlings. The Hoedad approach looks like the right way to go for that task. But I do need a post hole digger for replacing some old fencing. I'll take Gerard's advice and check out the Northern Tools site. I think it will be easier to convince the bride we need a $600 post hole digger than convincing her we need an $1800 tiller.
I might have to put off the corn and pumpkin patch to next year. Between the new trees, the fence replacement and the deck replacement, I'll have my hands full this summer.
Thanks again for all the help.
Paul
Gerard,
Thanks for the tip, I'll check out that Northern Tools site. In which county do you live? I'm up in Essex, about 12 miles from the Vermont border.
Garey,
I forgot to ask in my earlier e-mail, which blade(s) should I order for the Hoedad? I will be planting 100 spruce seedlings (about 10 -12 inches in length) and 50 doug fir 2 year old plant (about 18 to 24 inches).
Thanks,
Paul
/ What's the right attachment #9
Paulie
I'd use the Straight blade for most applications...The Rasmussen blade works best in sand/soft soil that wants to fall back into the hole...the plug blade is designed for seedlings that come with "plugs" of soil on the roots like the vegetable sets you buy at the garden center.
Mildly sharpen the top edge of the blade to act as a root cutter...If Needed, you can trim the roots on a seedling to about 3/4 of the length of the HoeDad blade without harming the seedlings...some of the seedling you get late in the planting season can have roots 18 inches long....really hard to get in the hole...and you want to get the tap root straight in the hole...not "J" rooted...if J rooted the tree will never grow right!!
The only "trick" to a HoeDad is....swing overhead and drive it into the ground...lift up about 1-2 foot on the back of the handle to start to open the hole...the push down and away from you...this will open a "pie" shaped hole to insert the seeding...after the seedling is straight in the hole, choke up next to the collar on the hoe and drive the hoe down about 1-2 inches behind the seedling, work the handle down then up to close the hole eliminating the air pocket around the roots...finally heel the plant in as you step across to the next hole...
Sound more complicated than it really is....shouldn't take more than a half dozen holes to get the hang of it....a good hand planter can walk/plant as fast as most people can walk!!
Hope this helps
GareyD
/ What's the right attachment #10
/ What's the right attachment #11
PaulieD,
If the Hoedad is appropriate for the trees, I wouldn't spend most of my implement budget on a post hole digger if you only have a one-time fence project. They dig so well that you could rent one and have all the holes done quickly. Besides, I bought one for a couple of jobs and have been tripping over it for 4 years. They don't store well.
If you agree, now we have $600 to spend for you. This board loves to spend other peoples money. I'd recommend a box blade. It would also help with driveway maintenance if you have one.
John
Garey, thanks for the very understandable, detailed instructions. It does sound a bit complicated, but I suspect it's a matter of learning the routine and sticking to it. I'm going to order a straight blade today. My seedlings are supposed to arrive in a couple of weeks. Thanks again, Paul
John, a couple of the guys at work have been counseling me to invest in a box blade. They both agree that it is a versatile tool that can be used for variety of jobs. These guys are also the ones that told me that once I got the tractor and FEL, the selection and purchase of implements would be a continuous exercise. They appear to be right on that score. Thanks for the help, Paul
/ What's the right attachment #14
Paul, you're welcome...glad to help.
Be sure to keep the roots moist on those seedlings...leave them in the sack if you can't get to them for a couple of days...if they come with "frog egg looking stuff" on the roots, try not to wash them off...they will help hold moisture on the roots after you plant them.
You can use a 5 gallon bucket with a couple inches of water in the bottom as a planting container.
GareyD
Garey,
Thanks for the tip on the hoedad and the instructions. A posthole digger would have been overkill. I put 50 frazier fir replants, 50 blue spruce seedlings and 50 white spruce seedlings in a few weeks ago and the fraziers and the white spruce are already showing signs of new growth. It took a while to get the routine and rhythm down, but toward the end we were moving along fairly well.
Now I still have a few bucks left for that box blade John suggested.
Thanks again,
Paul
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
John Deere 1025R (A62177)
John Deere 1025R...
