wha'ts the cost differnce?
/ wha'ts the cost differnce? #1
robert koch
mahindra
I am looking at buying a new 50 hp tractor so far i have just price the mahindra 5010 no cab just basic tractor gear drive just wondering is JD.NH. OR KUBOTA OR ANY OF THE TOP BRANDS THAT MORE EXPENSIVE ? please help
/ wha'ts the cost differnce? #2
well you can get a MX5100 2wd for prolly $20,000 new more or less.an thats a 52hp tractor.
/ wha'ts the cost differnce? #4
Guessing the Mihindra is going to be quite a bit less than the others you mentioned. I know the TYM603 we recently purchased was quite a bit less. One thing when comparing different tractors is to consider the price of necessary options configured on each. This can make a big difference in end cost of a tractor over the base price.
The best way to find out is to call or stop into local dealers and ask. Have a list of options, such as gear drive, FEL with joystick, # of rear remotes, PTO (540-1000), sway control 3 point, creeper, shuttle shift, etc, etc, If you are not sure about tractor models give then your HP requirements and list of necessary options and go from there. This will also give you a feel for how the dealer will treat you as a client which may make a difference regardless of cost.
Another thing to consider between the different machines will be output of Hydro system in GPM and lifting capacities of FEL and 3 point depending on tasks you will need to accomplish. If you will be using a lot of PTO attachments also consider the PTO HP rating for each machine.
Good luck
/ wha'ts the cost differnce? #5
For list price of a John deere you can go their website then find a model you are interested in and then "build your own" it will give MSRP. You can also request a quote from a local dealer. People report getting 10-18% off list depending on specials offered by John Deere.
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
1059 (A63291)
1059 (A63291)
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 Nissan Altima SV Sedan (A61574)
2015 Nissan Altima...
