Rotary Cutter Whats the biggest meanest rotary cutter for a.....
   / Whats the biggest meanest rotary cutter for a..... #1
CountryBoy
West Virginia (not western Virginia)
Something a JD 4410 could handle? I am talking about something you could wade into the brush and saplings and make it happen and hold up well for years.
   / Whats the biggest meanest rotary cutter for a..... #2
Re: Whats the biggest meanest rotary cutter for a.
Land Pride RCR 2660 or an MX6. I thing the John Deere 609 HD rotary cutter would be too heavy.
   / Whats the biggest meanest rotary cutter for a..... #3
I personally like a Woods because of the way the blades are removed. But if you want real heavy duty, you might want to look into a Brown. JMIII has one. Brown Rotary Cutters
   / Whats the biggest meanest rotary cutter for a..... #4
For your size tractor and available PTO hp... take a look at BushHog's Model 12 & 305 for Mid to HD cutting capacity and durability...
There are other heftier units out there... but I'm afraid your 29/30 PTO hp max is the limiting factor... along with the 3-pt hitch rating...
   / Whats the biggest meanest rotary cutter for a..... #5
I'd second the JD MX6 recommendation - I've got an MX5 and it's awesome. JD sells even heavier duty units in their HX series but I'm not sure your 4410 has the pto hp for those.
   / Whats the biggest meanest rotary cutter for a..... #6
How about a Rhino GR60? It requires a PTO of 30 HP, which is what I believe your 4410 is.
   / Whats the biggest meanest rotary cutter for a..... #7
Hi Dave,
The GR60 is an outstanding unit (I just got an older Servis unit)... but the gyro bar is very heavy... and I don't believe the 4410 could handle the 3-pt version... but obviously the tow/trailer unit... ~ 1300-1400 lbs?
Another Rhino choice would be the CY60... /forums/images/graemlins/smile.gif
   / Whats the biggest meanest rotary cutter for a..... #8
The meanest.. Rhino's "Lumber Jack" LJ72 has a cutting capacity of 6 inches... 2500 lbs and requires a min of 90 PTO HP.. deck is 1/4 inch.. sides are 1/2 inch thick.
   / Whats the biggest meanest rotary cutter for a..... #9
Given that CountryBoy only has a 30 PTO HP tractor, your choice is out of his league. /forums/images/graemlins/ooo.gif
   / Whats the biggest meanest rotary cutter for a..... #10
Gatorboy.. you are right.. got hooked on the title.. "biggest meanest".. I was just going for the meanest. The 5 foot medium duty cutters would be the limit for 30 PTO HP.
Deere 333G (A50120)
Deere 333G (A50120)
2024 John Deere 6110M (A50120)
2024 John Deere...
2025 Swict 60in Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
John Deere 47" Snowblower (A50774)
John Deere 47"...
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
